Old 06-24-2013, 04:48 AM   #1
overlander   overlander is offline
overlander's Avatar
Skyteam V-retro (raptor) 250 owner
Hi
I'm based in Australia and just purchased a skyteam v-retro 250. The V-retro is known as the v-raptor everywhere else!
I have a bike with the black colouring and call it the black wombat - coz it has a big rear end and doesn't move too fast! Unfortunately, like a wombat it has also been hiding out in the dark a bit too much of late. I've had some trouble getting it started. I ran it for about 15 km's then couldn't start it.
I've checked the spark plug (still throws a spark) I've tightened all connections around the carburettor. I've even taken it to a mechanic to tune. It then ran for about 10 km's, and then wouldn't start again.
Just wondering if anyone has had similar problems or can suggest solutions for what I can do to get the black wombat out of the burrow and onto the road!
Old 06-24-2013, 05:17 AM   #2
Trailbikeryder   Trailbikeryder is offline
Trailbikeryder's Avatar
Hi,
Welcome. Nice to see you found the way here Could you take some close pictures of the engine and carberator on both sides? Then I could compare to see if any of the fuel lines are hooked up the same way on my bike.
Eric
My CB : http://www.youtube.com/watch?v=ZbZ8q-grmOQ
2012 Skyteam V-Raptor 250
2011 Yamaha Tenere XT 660Z abs
1996 Kawasaki Vulcan 800 Classic
1989 Kawasaki GPZ 500
Old 06-24-2013, 05:55 AM   #3
tecnolli   tecnolli is offline
tecnolli's Avatar
Welcome!
Did you check the spark right as the engine quit, i mean in operating temperature? If not, it could be the ignition coil that fails when it's hot. Did the bike start again when it's cooled down?
Old 06-24-2013, 07:17 AM   #4
zingshoen   zingshoen is offline
zingshoen's Avatar
if you have a spark, is it fat and blue or orange and weak?
do you have enough petrol in the tank? does it flow into the carbie? that would be the second thing to check if you do get a good spark.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 06-24-2013, 07:34 AM   #5
overlander's Avatar
Wow, thanks for all the responses. It is night here and my hope is to take the bike back to the mechanic to have another look, hopefully get it running again. I really have no tools or experience with bikes. I will take all your suggestions with me.
There have been a lot of naysayers here in Australia with regard to Chinese bikes. Of three local mechanics, two would not even look at my bike! I imagine the same thing would of happen with Japanese bikes when they first started production.
I'm interested to hear from members who have had the v-raptor on the road for a while. Is it true one can use Honda CRF230F engine parts?
How would this motor go as a replacement? http://www.crossfiremotorcycles.com/...engine-4t.html
Old 06-24-2013, 08:52 AM   #6
I've had the same thing happen to me here in Germany also. A Kawasaki or Suzuki dealer didn't even want to do an inspection and check the valve clearance. Luckily I found mechanic in my town that is specialized on chinese scooters an bikes.
The Skyteam 250 engine actually has 223cc. Honda has for example the FTR 223.
which is the same engine as far as I know.
http://image.rakuten.co.jp/hatoya/ca...8ftr223dxm.jpg
Old 06-24-2013, 09:04 AM   #7
overlander's Avatar
Has anyone removed the exhaust baffle? When my bike was running, my neighbour came over to check it. He said it "looked like a harley, sounded like a postman's bike!"
There is a company in Australia that do a custom version of the v-retro (raptor). They call it the black betty
Old 06-24-2013, 11:27 AM   #8
Welcome overlander!
With the experience I've had with that engine, I'd say one or both of the valves are too tight. Setting valves is quite simple on these engines: http://hondacg125.awardspace.com/valve_clearance.htm Even if the valves aren't the problem, it's good to know how to set them properly.
Trailbikeryder, thanks for telling us about the FTR223; I was unfamiliar with that model, and I didn't realize that Honda produced the CG-style engine beyond 125cc.
Old 06-24-2013, 06:31 PM   #9
Pliskin   Pliskin is offline
Hehe
Welcome to the forum. I am subsribed to a guy on Youtube with the same name.
I had the same problem. One mechanic even screwed up my stator. If you can find somebody who you can trust (you can always try a Suzuki sticker ) or you'll just have to learn how to do it yourself. It's not that hard but it takes patience. I agree with Weld check the valve clearance just to make sure. You will learn a lot in short time, plus you'll save money.
Zongshen 200gy-2
Old 06-24-2013, 07:07 PM   #10
overlander's Avatar
I will print that out about the valve clearance and take it to the mechanic.
Yes, I make videos Pliskin, just back in Australia after near two years abroad. last place I went to was Cuba (loved it)
At some stage I hope to start making videos around Melbourne on my bike! Melbourne is represented by 70 different cultural cuisines, I want to try a meal in each countries restaurant, and make a video for each.
Old 06-24-2013, 08:53 PM   #11
overlander's Avatar
The mechanic can't fit the bike in today, had to forfeit the $41 booking fee with vicroads. He reckons if it was the valves he would not have been able to start it previously and it would have coughed and spluttered. The bike will have to sit in the garage now until I find time to get back here and find someone to get it running or buy tools and learn zen and the art of motorcycle maintenance myself
Old 12-01-2016, 04:46 AM   #12
thedoc62   thedoc62 is offline
thedoc62's Avatar
Send a message via Skype™ to thedoc62
engine shift
i have found on youtube a couple of vids of an aussie guy who took off the original engine from his v-raptor and installed a Zongshen 250 cc water cooled unit................amazing piece of job he did
the vids describe all very well, with particular regard to electrical connections (pretty tricky part of its work)
also included a vid of the running engine, its noise is wonderful and "full" compared to the previous OEM unit
Old 12-01-2016, 05:57 AM   #13
thedoc62's Avatar
i just chamged my exhaust terminal with a highway hawk black Megaton (or was it Megaphon ?) model
it is not for regular street use in Italy but I got it installed just the same, lowering its huge noise with a Dbkiller originally intended for use on VW Beetle engines
my "exhaust" mechanic had to work quite a bit with welding to adapt it but the result was nice in terms of looks and sound and performance
will add pics soon
the next thing i'd like to work on is the front suspension, suffering a lot (together with my poor ass and neck) on street holes and bumps, and the clutch (old story that all v-raptor owners know well)
Old 12-01-2016, 06:46 AM   #14
thedoc62's Avatar
there you go
Old 06-25-2013, 01:12 AM   #15
Wow nice to chat with you Overlander.
I love watching your youtube videos, they are very entertaining and educational. That tale in Cuba getting stuck for 5 days was very interesting. Communism best system in controlling nations, probably invented by freemasons. That's a great story that you are going to make. Hope you are going to get your bike on road soon. Keep us posted and people on this forum will help you. They helped me.
Zongshen 200gy-2
australia, skyteam, v-raptor 250, v-retro 250
