Old 07-02-2007, 08:47 PM   #1
TeamCheap   TeamCheap is offline
Hello my name is mike and I have been hiding a lifan problem
(Lifan support group)
I have had a slight problem with my lifan lately that has put it out of service until today.(I feel ashamed- :oops
It all started a couple of weeks ago while out riding, we were putting around the sub and my bike stalled I checked the plug, it was very hot (the plug) and dry but had a weak spark.I bled a little fuel out of the carb bleeder screw-Hmm fuel there-good-but will not start.
I just pushed it home it was just a block from my house and lightly raining.
A few days later with a new plug and a full fuel tank we gave it another try and it did about the same thing, run for a while then sputter and stall and not start.
After sitting a while it would start so I'm thinking maybe something is heating up and shutting it down (electrical) but I still go ahead and take the carb off and look for gunk in there and there is a very little amount of goo and a few small particles so I clean it all up.
We go for another ride and still the same thing, it runs great for a little while (few hundred feet to a few miles-always different distance) and sputters a bit then stalls and wont start for a few minutes (20 minutes or so)
So I decide go at it today.
With all the extra electrical components I have around here I start swapping out parts
(coil,CDI) to see if it could be an electrical part.NOPE.
So I do a backstep and start looking for the simple thing I overlooked long ago and found an odd problem.
All along I have stupidily overlooked the most important clue from the spark plug.
Anyone care to guess?
(clue-I had almost found the problem right from the start BUT....)
Old 07-02-2007, 08:56 PM   #2
Jeremy   Jeremy is offline
could it be the plug wire?
Old 07-02-2007, 08:58 PM   #3
jkomp316   jkomp316 is offline
Send a message via AIM to jkomp316
my car did the same thing when the intake was leaking?
Old 07-02-2007, 09:04 PM   #4
Nope not the plug wire and I even tried my spare coil-W/wire on it to no effect.
Not an intake leak, but it was running lean
Old 07-02-2007, 09:10 PM   #5
AZ200cc   AZ200cc is offline
A rat had moved into the exhaust pipe? Kidding
I am stumped...What was it? what was it? I'm curious now.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 07-02-2007, 09:14 PM   #6
yeah I was stumped to and the problem will blow your mind, very simple and easy to overlook.
I almost had the first look I took if only I had let.........................
Old 07-02-2007, 09:15 PM   #7
Was the choke stuck?
Old 07-02-2007, 09:18 PM   #8
nope not the choke it works fine and in fact the carb was perfect after cleaning out a little bit of junk but that wasnt the problem.
Old 07-02-2007, 09:20 PM   #9
So after today I had ruled out any electrical problem so that leaves FUEL.
Old 07-02-2007, 09:26 PM   #10
Alright, My last try A bad fuel line?
Old 07-02-2007, 09:31 PM   #11
nope fuel line is new I ditched the cheap black stuff when I did the engine swap.
Heres a big hint: the carb bleeder screw clued me into the problem.But the problem has nothing to do with the CARB itself.
Old 07-02-2007, 09:35 PM   #12
madmaximum   madmaximum is offline
Send a message via AIM to madmaximum Send a message via Yahoo to madmaximum
Intake boot?
2005 RSX-200E
2004 Suzuki Eiger
1999 Arctic Cat 250
1977 Kawasaki KH400, aka Green Ripper
Old 07-02-2007, 09:37 PM   #13
nope I thought about that and looked at it very close but its good.
Old 07-02-2007, 09:40 PM   #14
ok, lean, not carb......you're acting like it's something simple......vent hose??
2005 RSX-200E
2004 Suzuki Eiger
1999 Arctic Cat 250
Old 07-02-2007, 09:44 PM   #15
So heres what we know.
The tank is full.
The carb is clean and working perfect.
The electrical is fine and the plug is NEW.
There is good compression-I did not take a reading but it is good (new engine -apparently no damage done to it compression wise-and it has run well before this problem started)
The clue to whats going on is the carb bleeder screw.
