12-08-2012, 12:47 PM | #1 |
newbie has some Q's about a renegade
ok so I 'm new to the biking world , hi guys!, and i bought a qingqi renegade (baimo, jinlun etc etc) now i'm trying to do some minor fixes to it, but can't find the oil filter and the fuse box/single fuse, any help would be much appreciated!
12-08-2012, 10:03 PM | #2 |
IF the oil filter is as it is in the horizontal engine Hondas, (haven't opened my new Lifan engine to look yet), it is part of/contained within the clutch and a cleanable centrifugal type......IF your engine is a "vertical" motor, it's still centrifugal, but probably located on the end of the crankshaft (again, based on Hondas).....
A search just showed me yours is a vertical 125cc engine...... Fuse is USUALLY right next to/near the battery....... Steve |
12-09-2012, 03:58 PM | #3 |
so I can't take out the filter to clean it? and the fuse box evades me I've searched all over especially around the battery, guess i need to start taking apart the mysterious black boxes surrounding the battery. cheers mate this info helps alot!
12-09-2012, 11:44 PM | #4 |
Check for a large nut near the shifter shaft; that may reveal an oil strainer screen. Take care to not over-tighten it.
12-10-2012, 08:10 AM | #5 |
Most of these bikes only have one fuse and it is usually close to the battery under the seat. Typically the older glass type fuse.
12-11-2012, 05:08 PM | #6 |
cheers guys this info helps!!!!
