Need help with lightbulb
My Polysport headlight on the YZ uses what appears to be a BA20D headlight bulb, much like many Chinabikes.
I need to operate it off a small battery and need a muchh lower electrical draw. I'd like to go with an LED replacement. Although there are some in China (suppliers that only ship by the zillion units) I can't find anything on line. Does anyone have a lead or an idea? Is there a cross refrence of some sort to another bulb? It does not need to be exact or very bright, just legal and low draw. Thanks.
Happy to serve. |
I could be way off but try to look up what a 2007 te450 uses for a headlamp.
Or look on rockmtnatv. I think I saw one in their mag that looked similar to the ole gy shape.
KLR650, KLX300, Hawk GT 650, SV650, MX500, SSR 70cc |
I don't understand. :? Are you looking for a new, LED headlight, or do you seek an LED light housed within a BA20D connector? :?:
Spud ![]()
My Polysport headlight assembly uses what looks like a usual incadescent BA20D bulb.
Since I need to operate it off a 1,000mA rechargeable battery I need an LED bulb of some sort with a much lower current draw than the 35/35 watt BA20D. I was looking for a LED BA20D bulb to put in the existing socket but can't find one for sale in the US. ![]() My current plan, which may be temporary, is to adapt an 1157 socket with a commonly available 1157 LED bulb in the Polysport headlight assembly. It won't be as good as Plan A but it will be a light. I'm only trying to satisfy the law to have a headlight. I have no intention of using it at night so most anything will be OK.
Happy to serve. |
I think I have it figured.
I will adapt the housing to accept this bulb: http://www.ebay.com/itm/2-Pcs-H4-127...e2af9a&vxp=mtr Do you think this will be too much draw for the little battery?
Happy to serve. |
Do motorcycle headlights have to be on all the time like here in Canada? If they don't, and you only need a working headlight to pass inspection, can't you just keep the stock Polisport headlight and then keep it shut off the rest of the time? I love the idea of an LED replacement but I'm wondering if the one you linked to with 127 led's in it wouldn't use more power than a regular lamp? I'm not really qualified to answer though, because I know nothing about electricity, I'm just thinking that's a lot of led's!
T headlight needs to be on all the time on the road here in the US. Since I don't plan to ride it at noght how bright it is does not really matter but I'd like the visibility.
The 1157 bulbs I have only use about 9 LEDs. I don't know either!
Happy to serve. |
Well the bulb on the link tells you nothing as to draw/amps used.
It should be less than a regular 35w bulb at the least. |
That's what I figure also but I can't tell from the ad.
Happy to serve. |
LEDs use very little electricity, Doc.
![]() ![]() ![]() Spud ![]()
I may just go with the 1157 conversion then. It's more of a 'marker light' anyways. I wont need it to light the road per se.
Plus Since it has 2 'filaments' I can use it as a low and high beam, or in this case very low and extremely low. :wink:
Happy to serve. |
I would have liked a BA20D LED conversion as a drop in replacement but I can't find one.
Happy to serve. |
#13 | |
#14 |
I bought a couple 1157 LED bulbs and a socket. Maybe I'll just stick with that. I'll see if it will be easy or difficult to modify.
Happy to serve. |
#15 |
Happy to serve. |
