03-28-2012, 02:41 PM | #1 |
i was told megelli lost usa ,but this looks familiar
http://www.clevelandcyclewerks.com/b...nd-cyclewerks/ will have to wait and see , but the cheap china bike days on street legal appears gone . this one looks alot like the megelli supermoto bennche never brought to the usa. with some mods . look at the wheels and front rotors . and of course there was never a photo published of the megelli with the water cooled 250
03-28-2012, 11:27 PM | #2 |
Not exactly the same, but I think the engine might be the same? (Loncin 250 liquid-cooled)
03-29-2012, 01:07 PM | #3 |
Yes most of the similar items are the wheels,rotors and exhaust exit . could be that Cleveland cyclewerks has commissioned his own deal with available parts and not carry the Megelli name . Megelli engine is supposed to be an SYM engine ]
03-29-2012, 02:43 PM | #4 |
Do you still have your Megelli 250, Racer? I think I remember you were planning to sell it. Can you give us an update?
03-29-2012, 04:28 PM | #5 |
Still waiting on parts that i will never get . So i am in the process of self repair . After that i don't know . A megelli powered viva? (doubt it ) I do like the power it makes .
03-29-2012, 04:43 PM | #6 |
Please remind us; which parts do you need?
03-29-2012, 04:58 PM | #7 |
gas tank leak ,fuel petcock leak and fuel level warning sender . No worries ,already got a petcock ,repaired the sender and cleaned the braising and covered it in metal working solder . no visible paint damage on the outside . i had contact with 4 different people at megelli and i can not get a reply from any ( say pass the buck ) with that kind of service ,kinda makes the bike worthless . unless i can adapt other parts or get parts from there Australian distributor ,for future needs
03-29-2012, 07:21 PM | #8 |
Is it rideable now?
03-29-2012, 08:00 PM | #9 |
Not back together yet . As far as a bike to work on ,i love the Viva . i have tried 15 -20 mins at a time for 5 days to get the air tube back on the carb . sqeezes between the shock and the frame and that area is narrower than the carb ,no way to get a hand in there and the carb is only 1/8 of an inch from this narrow passage. to make a long story shorter the megelli is a pain to do almost anything on . This weekend i'll try another approach ,maybe remove the carb and put the tube on and push it through from the front to the airbox . :roll:
03-29-2012, 10:31 PM | #10 |
Can you switch to a pod filter? This is my favourite: 42mm Air Filter Cleaner 250cc ATV Quad Dirt Pit Bike
03-29-2012, 11:01 PM | #11 |
Couldn't use a pod filter in this case , the filter would be crushed between the frame and shock . I may also have to flip the shock back over ,i had flipped it to be able to access the air valve . you can not adjust the air in the shock when the valve is up top . I've never riden it with access to the air valve. i did it while it was apart this time as well as the swingarm mods posted in the street section.
03-30-2012, 01:01 AM | #12 | |
03-30-2012, 01:06 AM | #13 | |
03-30-2012, 01:34 AM | #14 | ||
BTW, the pod filter I pointed to has a really nice angle to it, so perhaps it would clear any obstacles.
03-30-2012, 02:07 AM | #15 |
I'm starting to think that method is best for installing all motorcycle carburetors, Weld. As long as the air box boot is flexible enough, that method will probably work best.
