08-27-2024, 07:54 AM | #1 |
17/40 sprocket setup for hawk 250
Well, since it has become abundantly clear that I won't be taking the Hawk off road anymore, I am interested in getting the RPM's as low as possible for street riding. I've seen several people on Amazon switch to the 17/40 setup. I understand I will lose some oomph. But my question is, will my 128 tooth chain fit? I've seen on Amazon that the 17/40 and 128 tooth chains are often bought together, but I wanted to ask you guys before ordering. Thanks.
2022 Hawk 250 |
08-27-2024, 09:36 AM | #2 |
A 128 link chain will work.
08-27-2024, 10:41 AM | #3 |
In my opinion , a 40/17 is not going to be a very good combination for you , nor for most people. I know you changed rear tire, and it reduced your gearing a little, but a 42-43/17 is really about as high as you should go. Some people that use the 40/17 have bikes like the TBR7, which has a smaller rear wheel, but on a Hawk, with an internally stock motor, and a hefty rider, living in a hilly part of the country, it's just going to make it hard to take off, and especially hard to take off from an upward slope. I think it would be harder on the bike than the few extra rpm that you want to reduce. I see post on the Facebook groups were people are recommending " crazy" combinations like 34/17. Jerry ran sprockets that ,if I remember right were 40/17, and was one of the few that was able to benefit from them, but he had a hotter motor, is under 200lbs, and lives in Louisiana.
08-27-2024, 11:02 AM | #4 | |
You should be aiming towards 1k rpm every 10 mph, or 5k rpm at 50mph. On my Xpect I run a 17/36t as ideal lowest gear. Been asking if the hawk has the same gear ratio as the Xpect, or not, and if it does, you should go with a 36-38t rather than a 40+t. |
08-27-2024, 11:28 AM | #5 | |
08-27-2024, 12:55 PM | #6 |
I ran a 17/40 sprocket set-up on the Hawk for about 4 years after porting and polishing the head of my CG250 engine and loved it. I could comfortably run 65-70 mph all day long on my local highways without overstressing the engine. If you're running primarily on the street and doing occasional light off roading (i.e., double track dirt or gravel roads, riding across fields, etc.), then 17/40 is excellent.
08-27-2024, 11:17 AM | #7 | |
2022 Hawk 250 |
08-27-2024, 11:24 AM | #8 |
With the 40 tooth rear sprocket, you can always drop down to 16 or 15 tooth front if you find it to tall of a gearing. I use to swap the front sprocket when going from street to off road. Easy to swap back and forth.
08-27-2024, 01:54 PM | #9 |
Did something happen?
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
08-27-2024, 06:38 PM | #10 |
having about 1 out of 3 days when my equilibrium is up to it. I went back on the trails with my son in law a while back and nearly dropped the bike several times due to my balance being off and I am just overall weaker this year. Been to the doctors but nothing is resolved.
2022 Hawk 250 |
08-27-2024, 08:31 PM | #11 | |
08-28-2024, 05:43 AM | #12 |
It's my fault. I've treated my body like an amusement park since I discovered alcohol and recreational drugs, and now I suffer the consequences. I have some plans to mitigate the damage, but we'll see what happens.
2022 Hawk 250 |
09-10-2024, 01:11 PM | #13 |
42 tooth and new studs
Okay, so I installed the 42-tooth sprocket and those fancy green-hued sprocket studs from Amazon. So far, I like it. It definitely makes riding at 55 less dramatic. Later, I will hit the backroads and see how badly it affects my ability to get up hills. I don’t really mind because 90% of my riding these days is back and forth to Wheeling on Route 2, where I do 55 the whole way, or around Moundsville. It also felt good to take off the wheel, inspect everything, and just give it a good once-over.
2022 Hawk 250 |
09-12-2024, 01:51 PM | #14 |
I wish we could change the thread title to 17/42 setup. Anyway, I rode a nice ride today, it's hard for me to believe that two teeth can make as much difference in overall riding experience. And it can still get my big booty going just fine. If you don't ride offroad much and you want a smoother experience, try it. worse case Ontario you can take it off.
2022 Hawk 250 |
10-03-2024, 09:38 AM | #15 | |
I geared it to be usable on road, able to cruise the 55mph river road to work and back, and up north and around Northern MI without buzzing at a million rpm. I'm roughly 5500rpm at 55mph with power and gearing enough in 5th gear to just pull up to 70 if needed (never needed yet). If I need more low end, I just drop the 15t front back on, or if the opposite, I can plop on a 17t front and readjust chain tension. good call on the 17/42. |
