06-12-2024, 11:45 PM | #1 |
Need wiring harness
New to this purchased a used coolster 125 had it running great did not realize there was a hole in the fuel tank so caught fire and trying to find the correct wiring harness for it leaving some help on determining model and also which wiring harness should I use please help
This is the number off of the swing arm You cannot make out the plate OZSCJLA2K1008311 NOV Please Help Thanks |
06-13-2024, 09:25 PM | #2 |
Pull the cover off the left side of the engine and determine if you have a 2 pole or 6 pole stator. Search Amazon or eBay and find a complete wiring harness for a TaoTao or Coolster ATV with the correct stator. Shouldn't be more than $35.
06-13-2024, 10:04 PM | #3 |
You can use an Ethernet cable for all data and signal wires outside of the starter, stator, and possibly headlight. It only handles about 1A per wire, too little for incandescent or halogen bulbs, and possibly led lights higher than 12W.
06-15-2024, 10:42 PM | #4 |
Wire harness for your Coolster ATV-3125R can be ordered from their website;
https://coolster.com/product/complet...-29-dql-ea012/
06-18-2024, 03:20 PM | #5 |
Walmart
