09-19-2018, 04:17 AM | #1 |
Why RPS bikes won't do 80MPH. With numbers
I know the lack of counter-balance shaft and liquid-cooling(unless you have around 100x82(XR 650L) and low gear ratios) would destroy these engines with sustained medium to high rev on long trips(even with oil cooler). But I wanted to compare an RPS Hawk/Magician bore and stroke and drive-train to two sustainable 80MPH(129Km/h) Japanese 250 dual-sports to see why the engine wouldn't produce enough output to do sustainable 80MPH on a flat grade even with sprocket mods.
2018 Kawasaki KLX 250: 72 x 61.2, 14/42 sprockets, ? final ratio(six speed) (curiousity)2009 Kawasaki Ninja 250R: 62 x 41.2, 14/45 sprockets, ? final ratio(six speed) 2018 RPS Hawk/Magician: 66 x 65, 15/45 sprockets, ? final ratio 2018 Honda CRF 250L: 76 X 55, 14/40 sprockets, ? final ratio(six speed) Conclusion: Bigger bore supports the shorter arm length that produces higher RPM and ability to gear lower in he top gears without pre-ignition or wrecking valves or over-heating. Explanation:
09-19-2018, 08:03 AM | #2 |
My Hawk has done 80mph. But I cheated, I was going down hill . Believe me, you don't want to do 80 on the Hawk. Anything past 70mph it gets a little sketchy with the knobby tires.
09-19-2018, 08:03 AM | #3 |
Tread lightly. Get a gps on that klx 250. The forum has some heavy hitters here. With tuning and deep pockets funny things happen. Not many jap 250 dual sports will run 80 on gps some wont with speedo off on knobby tires. Welcome aboard.
09-19-2018, 08:08 AM | #4 |
A good friend of mine has a newer Honda CRF250L (2016) and it crawls above 55mph, very little to no power. Granted, it gets up to 55mph marginally faster than the Hawk. I've driven his CRF250L on a number of occasions and it is somewhat more powerful, especially in the lower gears...tops out at about 62mph more or less on its stock config. It's definitely not $4000 more powerful.
The problem with high speeds (greater than 65-70mph) on the Hawk goes beyond just the engine overheating/not being able to sustain it. I would imagine the stock wheel bearings could blow out at those speeds, and it's not pleasant to ride that fast on knobbies on pavement.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
09-19-2018, 08:32 AM | #6 |
My 89 KLR 250 did 85 ONCE. I won't try that again. On knobbys it's pretty sketchy for stability.
That said it's got a 6 speed trans, 4 valve DOHC liquid cooled with at least 2x the HP. And it's a 6 speed. See how I did it? Way to light of a bike to go that fast even on 60/40 tires, just because you can doesn't mean you should. You'll know this too when you've done it. I'll compromise with 65.
09-19-2018, 03:47 PM | #7 |
my hawk makes it to 72 pretty good. I often will ride my hawk doing extended high rpm runs. I've commuted with the hawk on the highway, going about 50 mile round trip completely on the highway going 68, with the bike at 7k the whole way there. you can feel the power start to dwindle out at the top end.
My hawk is ported and decked aswell. it doesn't have any problems with extended high speed runs or overheating, and I don't have an oil cooler set up either. I ride trials tires, they are pretty stable at speeds, but have a light wobble. i dont notice too much. Most 250f's won't make it to 80 easily either. I've read from CCW that their heists supposedly can cruise at 80mph. They're using the same engine as the hawk, and the bobber they're selling is the same weight or more thsn the hawk. |
09-19-2018, 04:06 PM | #8 | |
09-24-2018, 09:40 PM | #9 |
I had a '90 DR250s, and with my friend riding it and me following in my 5.0 Capri, both speedometers saw 90+ mph on the 118 Freeway in the San Fernando Valley in the L.A. area-on two different occasions. Granted this was in the days looong before GPS (cell phones were around but rare), but both vehicles indicated the same mph after we had stopped. I recall him hitting 70+ mph on city streets (suburbs) with me chasing him. He was a much better rider who owned a CR500 which I can proudly claim I never dropped when riding it, including the numerous accidental wheelies I pulled riding on dry lake beds, but that is another topic for another thread...
09-25-2018, 03:54 PM | #10 |
Those of you who still have the stock speedo like I do, did you lubricate the speedometer cable? Mine is accurate up to 60mph (that's as fast as I have had it up to). Just a thought...
Kirk |
09-19-2018, 03:52 PM | #11 | |
09-20-2018, 02:04 PM | #13 |
I've run my little bikes up pretty well but 60 is about all I want to do. Spend the vast majority of my time around 45. Very comfy there on our twisties.
I'm with JerryHawk. Anything above 65-70, the bike starts to shrink quickly.
09-20-2018, 02:25 PM | #14 |
I don't trust the speedo's on these things at all. My GPS enabled app going down the road is about 10 mph off my bike speedo over about 45. So my phone says I am going 50-53 and the speedo is past 60. This is on a '18 Bashan Storm.
09-20-2018, 02:31 PM | #15 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 09-21-2018 at 07:34 AM. |
