Old 07-26-2018, 04:24 PM   #1
Appel_1978   Appel_1978 is offline
After market Fuel Mixture Screw????
So i saw a youtube video on a guy showing how to tune your fuel mixture screw and he highly suggested an aftermarket one like this. Of course he was demonstrating on a Jap bike. But it would make all our lives easier if we had one of these on our tt250s. No more using specialty tools or having to to take carb off and adjusting screw a little at a time. and better yet you can adjust on the road if need be if traveling. So for everyones sake can someone let us know what jap bike fuel mixture screw is comparable to our TT250s, Hawks, Storms and other china factory carbs. and also the michuni variant would be nice also. So we can get one of these and swap the pain in the @$$ factory one out. it would make tuning these so much easier......Lests start with the TT250 since thats what i own hehe.
"Take it easy, if its easy take it twice"
2015 CSC TT250
-Ebay exhaust
-Exhaust wrap
-Wingsmoto Air bent filter (POD)
-Outerwears prefilter for POD
-CSC jets 115 and 40
-15 weight front fork oil
-47 tooth JTR269.47 rear sprocket
-JT 428 HDR (128 link) Heavy Duty Drive Chain
-LED tail light bulb
-Auxbeam LEDF-S2 headlight bulb
-Brush hand guards
-30L removable tail box (ebay)
-3.1amp waterproof usb charger
Old 07-26-2018, 04:34 PM   #2
Chinabike   Chinabike is offline
I have this now on my hellcat 125cc just put it on yesterday, seems to work. on a vm22 carb
Old 07-26-2018, 04:36 PM   #3
I also have the flex jet kind but it didn't fit perfect.
Old 07-27-2018, 10:03 AM   #4
Kingraider   Kingraider is offline
Kingraider's Avatar
where is the fuel mixture located on this carb?
Old 07-27-2018, 02:16 PM   #5
bottom of my carb could be diff on yours. side or bottom
Old 07-27-2018, 03:19 PM   #6
Im assuming you are talking about the TT250 which is what i have. It is located on bottom front (front as in closest to front of bike) of the carb. Im not sure what the new ones look like but on my 2015 the screw was grinded down to look like a brass cap. but you have to take carb off and use a dremmle and small cutting disc to make a slot to be able to use a flat head screw driver to adjust it and or remove it and replace it with one that already has a screw head.
2015 CSC TT250
-Ebay exhaust
-Exhaust wrap
-Brush hand guards
Old 07-27-2018, 10:04 AM   #7
Kingraider's Avatar
i saw a spot on the bottom of my carb but there is a metal cap there
Old 07-27-2018, 01:31 PM   #8
blanc12   blanc12 is offline
I just ordered one for my hawk. I will let you know if it fits.
Old 07-27-2018, 03:20 PM   #9
If if fits does the hawk and tt250 have same fuel mixture screws? i know the carbs are different
2015 CSC TT250
-Ebay exhaust
-Exhaust wrap
-Brush hand guards
Old 07-27-2018, 07:50 PM   #10
I saw a video of someone using the same one in a pz30 and a vm26. I think it might work.
Old 07-28-2018, 07:05 AM   #11
So your saying a fuel mixture screw for a Makuni vm26 should work on the stock Hawk carb. Once that is confirmed then great we will have an answer to the Makuni carbs and the factory Hawk Carb. But what about the TT250s
2015 CSC TT250
-Ebay exhaust
-Exhaust wrap
-Brush hand guards
Old 07-31-2018, 06:43 PM   #12
Kivi   Kivi is offline
This is my self-made tool for mixture screw.
Old 07-31-2018, 08:49 PM   #13
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
I tried the generic red screw sold on line, and it didn't fit. The shape is close but the threads are off. So I turned one out of brass. The metric threads were 6mm x.075. The tip was so thin, .030 inch. It wanted to snap off !
Old 07-31-2018, 11:55 PM   #14
Nice work Red Hawk thats exactly what i want for mine. Id pay you to turn me one but i assume you have the hawk due to your name and not the tt250
2015 CSC TT250
-Ebay exhaust
-Exhaust wrap
-Brush hand guards
Old 08-04-2018, 10:40 AM   #15
DaveinOC   DaveinOC is offline
Idle Screw and Mikuni VM26 Clone on TT250
I bought one of the red screws and it fit fine on my Mikuni vm26 clone. The needle taper looks a bit different but it seems to work ok. I still have some work to do dialing in the Mikuni, but accel and off idle are now working fine - I just have a pretty bad backfire on closed throttle higher rpms. Here is what I have done to date:
  • Aftermarket exhaust "like everybody else has"
  • Airbox delete, trash can mod and pod air filter
  • Mikuni VM26 clone carb
  • Extended idle fuel mix screw
  • Jetting is (I think) 120 main / 25 pilot
  • Needle in 4th slot (1 rich from center)
I am pretty close on the carburetion but need to dial in the pilot mixture a bit more. The extended screw fitted fine, but forget requesting a color, I asked for black or silver and got red, LOL.
Before I dropped the needle clip to richen it up I had a bad hesitation just off idle, and richening up the pilot jet did not help. Dropping the needle clip to raise the needle and richen initial slide opening seems to have cured that issue. I am going to start a new thread with my results as soon as I get this dialed in.
1978 Husqvarna 250 WR
1991 Husqvarna WXE 250
2018 CSC TT250
