Skyteam Raptor 250-Odometer/tachometer
Hi guys,
has anybody experience with the odometer/tachometer from ebay/amazon?? 1. odometer: Is it right to use a odometer (I need it with km/h) with k=1,4? 2. tachometer: where to connect the rpm-cable...at the coil? What i want is to add a tachometer, max. 8000 1/min is enough. And perhaps to replace the odometer with one with black scale.
It´s never too late not to... |
i did not buy a new speedo, but i did buy a tach from ebay for about $6 and i have has no trouble with it (other than it is digital and hard to see when the sun hits it). there should be 3 wires on the tach, one to power, one to ground and one to the small wire to the coil (just as you said) and i have never gotten my bike up to 8k rpm, so you should be good there imo ... btw, i wired my power to my tail light, because the dash light that shows my lights are on is hard to see, and the switch to turn them off is easy to hit
#3 | |
![]() Those 13k like this https://www.amazon.de/dp/B017D82KI6 is easy to fit : Long wires (backlight) | B/Y: rev signal ...
#4 | |
does anybody knows the k-factor?
k=1 or k=1,4? perhaps i would buy this set; https://www.amazon.de/Wegmesser-Kilometerz%C3%A4hler-Geschwindigkeitsmesser-Tachometer-Hintergrundbeleuchtung/dp/B00MVNT0LE/ref=pd_sim_sbs_263_2?_encoding=UTF8&psc=1&refRID=Q TC2JV4955F0VS2PZP1H Reason: i want to have a tripcounter. the Raptor does not have one and don´t have a fuel-reserve-warning lamp, too. So you always have to remember when you filled up fuel last time -how many km you have driven since....
#6 | |
#7 | |
![]() Thank YOU!!
But you have a regular reserve on the petcock?
yes.... but it happens, that even i used not the reserve, the tank has been empty....
It is possible that the petcock is not properly marked; I've seen that. To be sure, remove the petcock from the tank (when it's empty) and gently blow air through the hose barb. Which tube has air passing through it when main is selected? It should be the longer tube. On reserve, the short tube should have air passing through. I've engraved a petcock to eliminate doubt after figuring it out.
Yep, I just did that on my Puzey last week, and can confirm once again that gasoline is quite bitter and makes your lips numb
#12 | |
![]() today i emptied the tank in "on" until no more fuel is coming, switched to "reserve" and no fuel come out. ![]() so...perhaps the marks on the petcock is wrong and also the photo in the manual.Anyway... I have to blow through the petcock. I will keep you informed about the progress
#13 |
it seems Isolved the "problem". I checked with blowing through the petcock, tubes of petcock dumped in water. So I can clearly see where the air is going through.
![]() When i let the fuel out... in "reserve" (thinking that was "on") until no more fuel coming, the tank w a s empty and so there is no more fuel coming when i switched to what i thouight is "reserve" (but was "on"). Now i filled up with 5 ltr.in total. Tomorrow, after hopefully pass the MOT (called TÜV in Germany) with my car, I want to drive with the bike, until to the fuel limit. Then I will see, if the knot was in my head. ![]() Better to take some fuel with me....
#14 |
@thedoc62...: are you still alive???
