10-14-2011, 12:58 PM | #1 |
Kill Switch Question
My kill switch has broken, it consists of 2 wires, will the bike operate (be on) when the wires connect or when the connection is broken. It's a Zongshen 250gs
thanks in advance |
10-14-2011, 02:01 PM | #2 |
Usually the switch will connect the terminals when activated, so it should run with an open circut. Easy to experement and figure out though.
Happy to serve. |
10-14-2011, 05:04 PM | #3 |
thanks,...normally it should be easy but I'm dealing with other issues so I want to make sure the kill switch is right before I experiment with the others, experimentation is easy but 2 experiments which depend on each other can be counter-productive, lol, really appreciate it though.
10-19-2011, 08:22 PM | #4 |
FastDoc is right;
On a typical 5-wire setup the kill switch grounds one of the CDI module pins when activated, it should be an open circuit when running. I have yet to see an actual manufacturer wiring schematic and this is based on just what I have seen - your mileage may vary. |
