06-06-2019, 10:10 AM | #1 |
New tt250 help
So bought new tt250 nice bike but having one issue basically when you try to give it 1/2 throttle or more the bike misses as it climbs through the rpm range if you feather it all the way through no missing only half throttle
Or more csc has been helpful sent me coil and new computer for the coil still same problem my First thought was fuel and I’m still leaning towards this being The issue any ideas? New to the forum thank you so Much |
06-06-2019, 10:23 AM | #2 |
Have you checked valves? This might help a little
Second thing is tune the carb or look into carb check jetting that’s actually in it I do have a set listed in my eBay store for first tune, this might be useful to you. So you changed the CDI and coil? Any color smoke when it plays up? |
06-06-2019, 10:25 AM | #3 |
Do you have a timing light? See if it’s loosing spark when it plays up etc
06-06-2019, 10:31 AM | #4 |
Also try a new plug. The one that came on the bike may be defective or cracked. I agree, valve lash would be one of the first things to check.
06-07-2019, 12:45 AM | #5 | |
Valve lash would be good check, mine were tight at 400 miles (I hope I did not damage valves) Bike runs great. Dad's valve lash was spot on at 100 miles. |
06-07-2019, 08:29 AM | #6 | |
06-07-2019, 11:48 PM | #7 | |
Had I known I would have set the valves from day 1. But another bike my Dads. tt250 was perfect, set on the loose side of the spec. I removed the side plate to rotate the engine, 1 out of the 3 screws was significantly tighter. Hmm they don't have a torque tools for assembly? |
06-06-2019, 10:35 AM | #8 |
Thank you both for response so the valves are due in the next 40 miles so I’ll be doing them this weekend yes replaced both under warranty and also spark plug was the first thing I did to see and no improvement with all three those parts replaced. Changed the oil already bike is about to hit 500
06-06-2019, 10:36 AM | #9 |
Also idk what size jets are in it that’s was my thought maybe needs a different main
Jet since it’s only 1/2 throttle or more I’m not to well with carbs but I’m Decent with cars etc so |
06-06-2019, 10:47 AM | #10 |
Try adjusting the idle mixture. It may be set to lean. Once you have the idle mixture set and it still does it then you can raise the needle up one notch.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-07-2019 at 07:52 AM. |
06-06-2019, 10:48 AM | #11 | |
Valve adj set, first tune set, carb air screw adjuster all could be useful to you I’m in the USA Saturday and have some products with me or it be 2ish weeks before I’m back If you’re lucky I might be passing thru your area if you’re west coast lol I have some items to drop off to customers already and it’s not the first time I’ve deluverrd in person |
06-06-2019, 10:52 AM | #12 |
Ok I’ll check it out. Do I have to take the carb off to change the idle mixture ? Think the older models don’t have screw but I believe mine does
06-06-2019, 11:16 AM | #13 |
The stock carb does have an idle mixture screw. It may be covered by with a plastic or brass cap that can be drilled out. It will be hard to adjust while on the bike but can be done. You want to adjust the idle mixture after the engines up to running temperature.
06-06-2019, 11:05 AM | #15 | |
tt250 help |
