Old 03-12-2023, 09:26 PM   #1
WeebleWobble   WeebleWobble is offline
WeebleWobble's Avatar
Templar X 250 air filter
Anyone know what other make/model air filters fit the Templar 6spd model? Would be nice to have a spare on hand to swap out.
Check posts #18 & #19 for replacement air filter details!
Templar X 250
Yamaha XSR900
Kawasaki Brute Force 750
Yamaha TT-R 50
Old 03-12-2023, 10:40 PM   #2
buzz   buzz is offline
How about a picture?
Old 03-14-2023, 05:18 AM   #3
PSM can quote you. Email Zora.
Old 03-17-2023, 11:31 AM   #4
Emailed PSM and after several q&a emails with Zora I was told the air filter is not sold seperately. It only comes as a assembly (the entire housing) for $70 shipped.
Templar X 250
Yamaha XSR900
Yamaha TT-R 50
Old 03-21-2023, 08:40 AM   #5
I noticed similar with a front brake line request. You have to order the entire front brake assembly.
Old 03-21-2023, 11:28 AM   #6
Sorry for posting this in the air filter thread...
Brake lines is something that should be universal. The banjo bolts are standard. The key is to get the right length and with the correct end (direction of outgoing metal tube before connecting to the hydraulic line).
You can get a pretty good length measurement with a cheap narrow flexible tape measure. I measured 51" on the front brake line for both 5 speed and 6 speed (and same fittings). You can upgrade to stainless steel at the same time. 50" is OK with slightly less poking up from the left fork over the handlebar.
ARH custom will make any (50" with any end, expensive!), but there should be a much less expensive alternative.
https://www.arhcustom.com/
By the way, some have noted weak brakes on the Templars. Some of this might be brake pad quality, but SS braided lines do stiffen up the brake and make it better (did this on a 1200S Bandit with definite improvement)
Old 03-17-2023, 01:48 PM   #7
GypsyR   GypsyR is offline
GypsyR's Avatar
Their factory/OEM parts support has come a long way but still isn't quite where it could be. Zora can only quote what they can get I imagine.
Anyway, back to the original question. I have no doubt in my mind that my air filter isn't bespoke. They grabbed one off the shelf for an existing application. If we can figure out what exactly that was then we would very likely have our choice of aftermarket replacements. I've looked at my filter and it doesn't ring any bells for me. Maybe if we removed one a posted up pictures of it?
Old 03-17-2023, 01:59 PM   #8
google this description. It is an amazon listing for a filter for $19
Air filter motorcycle air filter for KTM 85 125 150 200 250 300 350 450 500 for Husqvarna FE250 TE125 TE250 FC250 TC125 TC250 FC350 TC85 17/14 19/16 for Husaberg FE250 FE350 FE450 FE501 Air filter
that looks real similar and fits LOTs of bikes. I wonder...???
Amazon has lots of Twin Air dome filters too. We just need to know a KTM, Husq, other model or two that the Templar filter fits.
for KTM 77206015000
for KTM 85 SX 2013-2017
for KTM 125 SX 2011-2015
for KTM 150 SX 2011-2015
for KTM 150 XC 2011-2014
for KTM 200 XCW 2012-2016
for KTM 250 SX 2011-2016
for KTM 250 SXF 2011-2015
for KTM 250 XC 2011-2014
for KTM 250 250 XCF 2011-2015
for KTM 250 XCW 2012-2016
for KTM 250 XCFW 2012-2016
for KTM 300 XC 2011-2014
for KTM 300 XCW 2012-2016
for KTM 300 XCW Six Days 2015-2016
for KTM 350 EXCF 2012-2016
for KTM 350 SXF 2011-2016
for KTM 350 XCF 2012-2015
for KTM 350 XCFW 2012-2016
for KTM 350 XCFW Six Days 2014-2016
for KTM 450 SMR 2012
for KTM 450 SXF 2011-2015
for KTM 450 SXF Fact Repl 2012
for KTM 450 XCF 2012-2015
for KTM 450 XCW 2012-2016
for KTM 500 500 EXC 2012-2016
for KTM 500 500 EXC Six Days 2016
for KTM 500 500 XCW 2012-2016
for Husqvarna 77206015000
for Husqvarna FS450 2015
for Husqvarna FE501 2013-2016
for Husqvarna TE300 2013-2016
for Husqvarna FE350 2013-2016
for Husqvarna FE450 2013-2016
for Husqvarna FE250 2013-2016
for Husqvarna TE125 2014-2016
for Husqvarna TE250 2013-2016
for Husqvarna FC250 2014-2015
for Husqvarna TC125 2014-2015
for Husqvarna TC250 2014-2016
for Husqvarna FC350 2014-2015
for Husqvarna FC450 2014-2015
for Husqvarna TC85 17/14 2014-2017
for Husqvarna TC85 19/16 2014-2016
for Husaberg 77206015000
for Husaberg FE 250 2013
for Husaberg FE 350 2013
for Husaberg FE 450 2013
for Husaberg FE 501 2013
for Husaberg TE 250 2013
for Husaberg TE 300 2013
Old 03-17-2023, 04:31 PM   #9
Tusk has at least one dome filter for $20
It is part number
TK-1541153bd5-8b5508
If any of these fit the base plate, you can shim the threaded rod screw or replace it with one that fits better, and it should be fine.
If you do, tell us about it! Please!
Old 03-20-2023, 10:54 PM   #10
I finally got around to pulling the stock air filter on my Templar X (250cc 6spd).
Length 7 3/8"
Width 7"
Height 2 7/8"
It has one pin to locate it on the filter cage.
*My owners manual shows a picture of a TwinAir filter on pages 36-38, but it is either a generic picture or possible a different model (maybe the 223cc motor?).
Templar X 250
Yamaha XSR900
Yamaha TT-R 50
Old 03-20-2023, 11:07 PM   #11
Just noticed the filter cage has a odd shape to it.
Templar X 250
Yamaha XSR900
Yamaha TT-R 50
Old 03-26-2023, 08:08 PM   #12
DanDLion   DanDLion is offline
What is the best way to get access to the air filter on the Templar X 6spd? Is it one of the side panels, or do you take the bolts off on the ring of the boot?
EDIT: My bad its through the battery compartment, very clearly visible, I just missed seeing it earlier when I was in there.
Old 03-26-2023, 09:01 PM   #13
Yup...Remove the seat, remove the battery, remove the battery cradle (four bolts or screws). There is a long stem bolt with a wing nut in the middle of the filter. That's it.
Old 03-26-2023, 10:46 PM   #14
For those following this thread, I've ordered a different aftermarket RMZ250 filter to see how it fits. Will update when it arrives.
Templar X 250
Yamaha XSR900
Yamaha TT-R 50
Old 04-10-2023, 11:41 PM   #15
UPDATE!
Got the second filter today. This one was also purchased off of Ebay and is made by LOPAR. Part number is 153215 for Suzuki RMZ450/250/RM125/250. It has the same general shape/height of the oem Templar X air filter that came in my bike. The only difference I see is:
On the oem filter, the locating pin hole is on the lower sloped side of the filter. On the LOPAR filter, it is located on the high side of the slope. Does this make a difference? Doesn't appear to as there is sufficient room in the airbox housing.
Templar X 250
Yamaha XSR900
Yamaha TT-R 50
