help me find this brake rotor and hub
I have a Vitacci Cougar Sport 200 that the PO screwed up. I am in need of a rear mounting hub and brake rotor for this ATV. I can't seem to find anything compatible on VMC or Partskit.
Its a single rotor in the back, about 220mm diameter. 4 bolt. Hub has an inside shaft diameter of about 40mm and 34 splines. 4 bolts about 65-ish mm center to center across the hub diameter. Anyone have any ideas where to find what I need? I don't care if the new disk and hub are 4 bolt or 6, It just needs to fit the splines and be about 220mm |
I would contact the distributor Vitacci direct. That's who imports them and has the parts. sales@vitacci.com
