07-22-2021, 04:36 PM | #1 |
Tao tbr7 information needed
I got The nibbie 30 carb got aftermarket exhaust on I’m at sea level I’m gonna try put on the carb will it go easy or have change things and Jetting In it stock has my plug white as can be. It runs aweful any advice be Much obligated
07-22-2021, 04:39 PM | #2 |
Running lean. What size main jet are you running? Try the size larger jet you have.
07-23-2021, 09:31 PM | #3 |
Running a 125 jet on stock carburetor, runs great.
07-26-2021, 06:18 PM | #4 |
I put a 122 in it won’t idle boggy
07-26-2021, 08:44 PM | #5 |
Main jet doesn't greatly affect the idle. Pilot jet and idle mixture adjustment is where you should be looking.
dual sport, dual sport enduro |
