Old 12-11-2013, 10:12 PM   #1
ManOfActionDT   ManOfActionDT is offline
Oh No Zong Sierra No Spark...what am I missing?
I recently purchased a Zongshen Sierra in a no start condition. Checked compression was at 120psi. It currently is not getting a spark of any kind.
Here is what I’ve done so far:
Carb rebuild
Ground / wiring continuity check
Replaced (Taobao / DHL are awesome…)
Spark plug
Battery
Ignition coil
Stator coil
Charging coil
Rectifier
CDI
What am I missing? Please help and or point me to similar posts of the same subject?
Thank you
Old 12-11-2013, 10:16 PM   #2
Tvnacman   Tvnacman is offline
Send a message via Skype™ to Tvnacman
post a pic of the cdi and stator , be sure to show the wires and plugs on both .
John
http://www.nycscooterparts.com/
For tech help call John 2125980016
Old 12-11-2013, 11:05 PM   #3
Welcome!
Excellent bike. I'd set the valves before doing anything else; 120psi sounds a little on the low side.
Spud will be along soon to address your no-spark condition.
Old 12-11-2013, 11:14 PM   #4
I suggest you check the resistance of the electrical components.
http://www.chinariders.net/showthread.php?t=12571
Old 12-11-2013, 11:18 PM   #5
Tvnacman - Are you asking for pictures of the connection on the stator coil? I have it installed... I'll get pics of both connections tomorrow...
Weldangrind - Thank you... I was hoping to get the no spark taken care of before tackling the valves... but if that will help I can certainly do it... it's in the proper "prepped for surgery" condition at the moment
Old 12-12-2013, 01:07 AM   #6
Ohm ohm ohm
I checked all of the them before replacing the parts... I'll check the new parts again and see how they read...
Old 12-12-2013, 01:10 AM   #7
If you have time, please post the resistance readings you get for each component. The actual readings will help us to troubleshoot your problem.
Old 12-12-2013, 04:17 AM   #8
zingshoen   zingshoen is offline
zingshoen's Avatar
on the aussie version there s a one way kill switch on the clutch lever and one on the sidestand.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 12-12-2013, 05:59 AM   #9
There are no safety switches on the U.S. version of the Zong.
Old 12-12-2013, 04:19 AM   #10
zingshoen's Avatar
do the lights work? does the neutral gear light come on?
Old 12-12-2013, 06:01 AM   #11
Indeed, make sure the battery is good. However, the bike should start with the kick starter, even if the battery is dead.
Old 12-12-2013, 10:55 AM   #12
tpar1220   tpar1220 is offline
i nearly ran battery down on my um dtf200 before realizing kickstand had to be up for it to run. it would crank all day long but no spark. soon as i raised stand.... fired right up!
kinda strange though, every other bike i have had with a safety switch would start in down position. not the dtf200 though..
Old 12-13-2013, 12:49 AM   #13
Electrical
The lights work... it indicates when in neutral... Haven't had a chance to check the resistance values... will do that Saturday.
Old 12-13-2013, 01:25 AM   #14
Oh No Question?
Does anyone know of a wiring diagram for the US version of the Sierra? I have the Euro version with the clutch lever and side stand kill switches, but my bike as far as I can tell (no wires near the side stand) doesn't have them.
Old 12-13-2013, 01:47 AM   #15
Your U.S. version of the bike does not have any safety switches. Everything else on the European wiring diagram should be accurate.
no spark, sierra
