02-12-2017, 07:51 PM | #1 |
MIKUNI VM26 Carburetor BETTER Idle Screw
I put the mikuni carb on my 250 Hawk and i love the better performance. The ONLY thing i dislike about the carb is how tiny the idle screw is and that it requires a screw driver to adjust it. The stock carb, for the hawk, had this big ass head on it that you could easily adjust with your fingers.
So i was wondering if anyone knew of a replacement that would fit the mikuni and also work similar or close to the original idle screw on the stock carb Photos of both Idle Screws: Stock.jpg Mikuni.jpg |
02-12-2017, 09:27 PM | #2 |
I would like to know that as well.
02-12-2017, 10:05 PM | #3 |
I should also mention that a solution i had was to buy a small phillip's head screwdriver key chain. But it's still a big pain in the a*s to mess with the idle screw. Plus i cant tell you how many times ive dropped the damn thing trying to adjust the screw. I would just prefer something that would be permanently on there and simple to adjust.
02-12-2017, 11:46 PM | #4 |
This should work:
http://www.ebay.com/itm/191539860297...%3AMEBIDX%3AIT I just ordered one for my vm26.
02-13-2017, 12:12 AM | #5 |
Do you have to adjust the idle that often yer need a big ass screw...
If so I think something needs looking at... .
02-13-2017, 10:05 AM | #6 |
I agree with Pete. If you're having to adjust the idle screw that much something is wrong.
I never have to touch mine and that's how I would expect it to be.
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs |
02-13-2017, 10:16 AM | #7 |
Same here. once I changed the jet, adjusted idle mixture and shimmed the needle I haven't touched it again.
02-13-2017, 07:32 PM | #8 |
Usually only have to adjust it from a cold start, once the bike is warm/hot its all good. When im leaving my garage, sure its fine to adjust it and let it warm up on a higher idle. then lower it back down. but if i leave it parked somewhere for a while and get back on id have to mess with the throttle until the bike warmed up. Its winter and very cold right now and haven't been able to test it in warmer weather but i still like to be able to adjust things easily without having to have tools on me all the time
02-14-2017, 12:40 AM | #9 | |
02-14-2017, 10:53 AM | #10 |
Yes, I agree with Pete yet again. I agree the pilot jet is too lean. It is not normal to have to warm up an engine past a few seconds in order to get it to keep running. Here's my routine. Turn on the fuel. Apply full choke. Turn on ignition and start engine with the throttle no more than 1/8th open. Keep throttle open for a few seconds until engine will idle. Put on helmet. Set choke to halfway position. Put on gloves. set choke to off position, pull in clutch, put it in low gear, Ride off. ARH
02-16-2017, 06:55 PM | #11 | |
i actually experienced the opposite (arizona elevation), i went from a 20-30 and had issues with cold starts, back down to 20 solved it. |
02-25-2017, 11:57 PM | #12 | |
is there a pilot screw people are swapping out the stock one with?? im using the one that came with the Mikuni carb i would think the stock one should work fine? |
02-13-2017, 10:19 AM | #13 |
I just installed my carb and Iam adjusting it a lot. My old carb had an easy to adjust idle screw so i would like one for my new carb. Once I get it set up I hope to not have to adjust it much but going from 10,000 feet to 5,000 always seems to mess with my idle lol.
02-13-2017, 12:18 PM | #14 |
What about soldering or brazing a coin onto the end of it ?
02-13-2017, 02:09 PM | #15 |
Something to consider, some of those oversized idle or pilot screws add a lot of weight outboard of the threads in the carb, and can wag under vibration, and Waller out the threads over time.
carburetor, idle screw, mikuni |
