Solenoid Chaos and a Bruised Leg
I had to replace my starter solenoid, so I ordered a Chinese one off EBay for $6.
It didn’t have a fuse like the one on the Hawk so I recycled the fuse assembly from he previous solenoid and wired in the new Chinese solenoid. It worked! Started fine 4 times, then nothing. I rechecked everything, all good. I can start it by jumping the solenoid with a screwdriver so I know it’s not the starter or the cutoff switch. When I press the ignition button I can hear the solenoid push the internal spring but nothing happens. So what killed the solenoid? Why did it work 4 times and then die? I don’t know much about solenoids, are they easy to kill somehow? I’m real tired of kickstarting, my foot slipped the last time I started it and I left a good amount of skin on the kickstart lever... |
possably the $6 prise tag is a bit of a hint as to what happened...
Ha I agree, financial decisions are the root cause but what is the mechanical cause?
Sorry, I didn’t understand that last post. Some Chinese stuff is good, some bad is maybe what you’re driving at?
#6 | |
I think the link and post is saying Plated Copper contacts bad, solid copper contacts good. Basically you get what you pay for... A buck fifty per start is kinda expensive... which reminds me another saying I heard: you can go broke trying to save money, or something like that.
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
Looks like you can get em on amazon. better than waiting for shipping from where ever.
Even if it is not the same it looks like it might work. https://www.amazon.com/Starter-Solen...SIN=B007X6R9PI |
#8 | |
Make sure you aren't loosing voltage at the relay on the trigger side, not the starter side. Sounds like a heat issue from a bad connection. Possibly a grounding issue. |
I had same problem and it ended up being my starter. It easy to remove and check.
hawk, kickstarter, solenoid |
