Some subtle mods to TBR7
sorry guys, but I don't like the look of all the extra plastic parts that are on the bike. So I removed the tank sides, exhaust "shield" and the brush guards. I added a harbor freight 3800 case to the rear rack. I think it gives the bike an old school cleaner look. Thoughts?
I thought about keeping the tank tabs and adding a tank vest. I have no idea how to run a sewing machine. So I’m stuck here. It looks like a Kawi 650 is the only type available. I’m almost certain it won’t fit.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! Last edited by Red Hawk; 10-18-2019 at 10:21 PM. Reason: Spelling |
#4 | |
In either case, I would bet you a car interior shop could whip something up like that for you, or just post an ad on facebook marketplace or craigslist looking for somebody proficient in such things.
[QUOTE=Megadan;321874]That's actually really interesting, but I must admit that I have never seen such a thing before. i am assuming those strips on the outside are velcro? Is it for holding things or just a way to protect the tank?
It’s Molle and that replaces the old ALICE clips, it’s how pouches are mounted. (Hint!! never volunteer for anything) Great idea to hold a tank bag anywhere or pop it off for not this ride today. The idea was to cover the tank less invasively if I changed my mind later something I’ve never done ![]()
#6 | ||
They are quite useful, you can attach different types of pouchs Same motorcycle with some pouches. Quote:
I guess those mole could helpful to a hunter than may be able to mount the gun to the side of the tank, some ammo holders to the other side. |
#7 | |
but the cover shape looks like it would fit a DR650 tank better... .
So basically it's a modular tank bag lol.
I agree, it is a great place for an oil cooler setup. Mine isn't as fancy as Jerry's dual setup, but it works just as good.
#11 | ||
I have a 1993 KMX 200 2t water cooled, those early models only had the side tank plastic on the radiator side. Later models added an extra side plastic to the other side for aesthetics and homogeneity.... |
#12 | |
It works fairly well too. On hot days you can actually feel it working. Sitting at a traffic light with the motor heating up you can feel some clutch fade happening from the heat soak, but the second you get moving the clutch fade... fades, and goes back to normal very quickly. Without the cooler, the clutch fade was just a fact of life, even at speed. The engine case may shed heat from the oil, but it isn't very efficient at it. Oil life is also improved rather noticeably as a result. In my case (and a few other guys now) with higher compression, a ported head, and soon a cam (wink) with a larger than stock carburetor, this motor definitely kicks out some more heat. On my last ride home it was 44 degrees outside, and that oil cooler was still almost too hot to touch when I arrived at home. after just 11 miles of riding. I do admit that I would like to add a thermostat to the cooler system and better lines at some point, but for now it works rather well. Warm up takes a bit longer, but not excessively so.
#14 | |
-- 2020 Taotao tbr7 |
#15 |
I used 1/2" electrical conduit clamps around the rack and fixed them with countersunk 1/4-20 screws inside the box
