08-07-2020, 11:24 AM | #1 |
Low Beam issue - Hellcat 125cc
I've been running into an issue with my hellcat where the bulb went out in the front. I took it out and replaced it, but now only the high beam works when I hit the flasher switch/trigger. Nothing happens when I flip the high beam/low beam switch itself.
I assume this is indicative of a bad switch? I need suggestions, or otherwise maybe links for the cluster (or headlight switch, if it doesn't need a full replacement) on the left handlebar. |
08-09-2020, 03:54 PM | #2 |
did the original bulb actually burn out on the low beam? check that first.
just a suggestion. |
08-10-2020, 11:23 PM | #3 |
It did, the bulb was near black and the filament was broken.
