Old 09-02-2022, 07:16 AM   #1
KPM   KPM is offline
KPM200 - Oil Strainer Cover Bolt
Does anyone know what this bolt is for ? Not sure if it's a bolt or a drain plug of some sort (It's not the crankcase oil drain plug).
Old 09-02-2022, 07:30 AM   #2
That's the cover for the oil screen. You need to remove it to clean the screen when doing an oil change.
Old 09-02-2022, 07:38 AM   #3
Here's a service manual for the KPR. Engines are the same so should help with any engine work you need to do. https://cdn.shopify.com/s/files/1/02...f?v=1636701098
Old 09-02-2022, 02:49 PM   #4
KPM   KPM is offline
Thanks JerryHawk250. Forgot about it when I did my oil change @200 miles. Will clean it out at the next oil change @ 500 miles.
Note: Edited subject line in original post so in the future it could help others in a search.
