04-07-2010, 12:33 AM | #1 |
dirt bike tire tubes..
can anyone tell me about the lock nut on the tubes to the rim... are they suppose to be kept loose..I have been told that if I tighten them it will tear the valve stem from the tube.. is this right??/
04-07-2010, 02:15 AM | #2 |
I snug 'em up without much torque.
04-07-2010, 03:42 AM | #3 |
Some of the tubes I have been getting lately (Michelin) don't have a threaded valve stem, but the "usual" is to snug them up.
One thing I haven't seen lately is a tire lock, usually found opposite from the valve stem (on the rim), it locked the tire to the rim. Maybe a thing of the past? |
04-07-2010, 11:22 AM | #4 | |
Our humble bikes, runnning dual sport pressure don't need them.
Happy to serve. |
04-07-2010, 11:23 AM | #5 |
I think that they're still quite common for the woods bike / motocross crowd, but they don't make sense for a dual sport. Tire pressure is generally higher on a DS, so a rim lock becomes redundant. IMHO, they also serve to unbalance a wheel at high speed.
On my XR, I tighten the rim lock securely. I don't want to spin the rim inside the tire (like what happened to my son).
04-08-2010, 12:36 AM | #6 |
TUBE LOCK
Thanks for the info.. I had a friend go thru a couple of tubes.. ripped the valve stem right off of the tube.. I do not know what he did.. tighten them or left them too loose.. you never get the whole story.. but I will just snug them up alittle thanks everyone..
04-08-2010, 12:42 AM | #7 |
When my son ripped the valve stem off, he was riding a bike with no rim lock, low air pressure and very low gearing. The fix was to install a rim lock from an RM80 (since it was only a 14" rear rim) and increase the pressure to 15psi.
