09-07-2018, 01:16 AM | #1 |
2018 Bull 200 New Tires - Sunf PowerII
Ok, so after about two weeks of deciding which tires to install, I went with the SunF PowerII tires. I have not ran them yet, but they look mean, and should do very well for trail riding.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
09-07-2018, 09:02 AM | #2 |
I think you will like those tires. The tread design is the same as what we use on our SxS (pic). The treads are very universal and work well on a variety of surfaces.
09-07-2018, 09:15 AM | #3 |
Looks good. I was looking at those same tires for my daughter's UTV. Either going with a 25" or 26" diameter tire. The 22" tires doesn't give her enough ground clearance and she is constantly getting hung up in the deep ruts.
09-07-2018, 10:49 AM | #4 | ||
One other thing I forgot to mention is that the measured diameter is very close to the size. They are about a 1/2 of an inch shorter give or take a little from the listed sidewall dimensions. The blue commander in the background has tires on it that are over in inch shorter in diameter than what is listed on the sidewall.
