Just came home from work, got tired of taking local roads so i said screw it! Jumped on the high way and it kept up more than fine! 17 minute ride and i got up to 66 STOCK.had my phone GPS speedometer. Gonna do sprocket change soon but i have no complaints! This bike holds its own on the high way!
#2 | |
Nice! Our speed limit here is 75 mph so I'm not even gonna try hahaha. |
#3 | |
Limits out here are 65, 75, and 80 mph depending on where I ride on the Interstate... and some of you wonder why I tuned up the little Bashan 200 to push 90 mph ![]()
#4 | |
Once I'm above 70-75mph that's too fast even on my Harley which weighs 650 lbs. and can reach speeds above 100mph wide open. Feels like my helmet is going to rip off my head at that speed.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
#5 | |
Late to this party, but not bad. I never found my Hawk to struggle with keeping up in traffic as long as the highway speed limit wasn't above 65mph. I had the bike to over 70 a few times, but being so tall and light it was definitely about the limit of my comfort zone on that bike.
In contrast, my VFR1200 - a bike that can effortlessly reach well past 130mph in a VERY short amount of time (top speed is 187mph at redline in 6th gear) - is almost boring to ride even at 90mph. Dead stable and drama free, and only the slightest bit of buffeting on my helmet if it sit up straight.
You're a rare case and I'm impressed!! I'll work on my bike but the most I'll comfortably get out of it is 68-70mph and that will do more than for a 55mph limit. You must have a lot mods!!
Ours is 55 so wasn't bad at all! I def would not try at 75mph speed limit lol
I meant to ask how your tires were, did they wobble or walk around much at speed? Grooved road sections causes mine to walk pretty bad and I have felt the tread wiggle in some cornering moments.
I have 1,300 km on mine stock with the stock tubes and no problems yet. I have been using about 35 psi in both, I fear the rain so am running them a tad low of what is printed on them (40psi), rain is often here lol. For off road the only times I have gotten into the real stuff I forgot to lower the air pressure but they were great until I hit the thick wet river gravel. The front just sunk instantly and the rear span out leaving me stuck a lot. I wonder how they do on snow/ice. |
#9 | |
#10 | |
I think Bashan gear theirs for the open road (vs. off-road like the Hawk) from stock; I think you should play with exhaust, carb (at least jetting), NGK plug, etc. before gearing (I have to admit, have not read any threads you might have started if you have tried these other mods already). How many miles are on the bike? If new(er), you have more speed once the bike gets worked in.
#11 | |
@Buffalorider - Awesome that you got the Storm registered and on the highway. After doing some mods to my Hawk...rejetting the carb to a #120, installing the aftermarket exhaust as well as the 17T/45T sprockets, it gets up into the 60mph range in 5th gear. I have about 100 miles on the engine now so it's getting closer to being broken-in. I tend to stay off the highways and stick to regular roads where the speed limit is generally under 55mph (knobby tires definitely wobble once you're above 50mph). We'll have to compare bikes at some point since you're in the area!
#13 | |
#14 |
My list of mods is buried somewhere around here in my thread
![]() Denso Coil on Plug, Denso Iridium Spark Plug, "tuned" air filter/intake system, custom exhaust, 17/39 sprockets, cheapo Mikuni carb upgrade, and I put the fatty bike on a much needed diet to name a few things I did... Still working on finding time (need my other motorcycle on the road first) to port/polish (my "think outside the box" way) and deck the head for better flow and a slightly higher compression ratio... also want to see if I can get a custom piston kit made for the thing too... lighter and stronger is always nice to have ![]() I know I won't be happy until I can either reach triple digits or I find out a 197cc China Bike will travel back in time if I go any faster ![]()
#15 | |
If your bike can reach 88mph, you might be in luck with one of these on there... https://www.rakuten.com/shop/mandnme...RoC2g0QAvD_BwE
