Head pipe smoking normal?
Today I saw smoke coming out of the bike I thought it was the engine but saw that it was the head pipe smoking for the first couple feet. Its only 2 days old and the header came black. Is it just the black paint burning?
It's just the paint burning 5star. It will get a funny 'plastic burning' smell to it also sometimes. Don't worry it will go away after you ride it a few miles.
Double check to make sure there are no wires touching the head pipe. Other than that you should be O.K.
'Desert' Drew Shineray DB-P12 'Speedee' 200 ![]() |
I put 40 miles on n it still smokes
Might have been something on it that is taking some time to burn off..Perhaps for shipping across the ocean.
Mine took about 100 miles. Also check to make sure the head pipe to cylinder buts are tight. They work loose fast.
Allen
Most likely your engine is running way to lean, since you gutted the muffler the jetting is way off. Be warned if you don't re-jet the carburetor you Will Burn up that new engine.
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
#7 | |
OMG, yes it has a Real carburetor on it. I told you in another thread that I most likely have jets for your carburetor. There are no jet kits made for any of these Chinese bikes or designated {very few} aftermarket parts. 150 degrees for oil is not bad but what are your other engine temperatures at? If your head & cylinder temperatures are too high then you are in trouble. Oil temperature is not the only thing you need to worry about, metal temperature is very important also. I have been setting up racing bikes for years and I worry more about metal temperatures than oil temperatures. If your engine is smoking already you have done damage to it. You can't just do modifications or through parts at any motorcycle and expect it to be ok. Changing pipes, carburetors, cams, air filters etc. means you need to change everything for air/fuel intake to keep the engine running correctly. Do us another favor....get a Google tool bar, it has a spell checker on it and will spell check anything you type in your browser.
#9 | |
I think jets for keihin carbs fit? Red has rejetted his. Look in the dualsport cross-reference parts for the jets. I know a link is in there.
Allen
The main jet in mine is a 98. The pilot is a 40. I checked my jets and my smallest is like a 148 so none of mine will work but they did fit and their keihin.
I was wondering would I gain performance if I port the stock carb from the stock 30mm to like 32mm or is it already big enough? I think im going to port the intake and exhaust port soon to |
I don't know what to suggest size wise as that is beyond my level. I think it may benefit from a larger carb if you are serious about bumping up the power.
Allen
#13 | |
I also removed the choke for a little better air flow. Now for starting I will probably have to put a bigger pilot in and then it should start in the cold. |
#14 |
Do the streetbike use the same type of carb as the Dirt bikes? We have the slide type carbs with the cable running into the top. If so you can also raise the big needle in the carb by moving the c-clip to the bottom notch.
I have heard also that the header pipes have manufacturing chunks left in them blocking flow too. Is there a high temp clear coat paint that you can use to paint it. Allen
#15 | |
Yeah same carb. 99% sure its the same as the xr200r carb to. There is high temp clear coat 1500 degree but it cant stand the heat of a bike quad motor. I tried it before and it burns and flakes off. I polish alot of things even a whole frame and found that if yo uclear coat polished steel it looks the same as if it wasnt clear coated but if you clear coat polished aluminum the clear coat fogs the shine up really bad making it all blury. |
