110cc brake issue - need help
Back brakes quit working, determined it was the brake master cylinder. Ordered a new one from VMC, fit is fine but the banjo bolt size is different. The new one is a 10mm, the one I took off was a 6mm or 8mm. Does anyone know where I can find a master cylinder with a smaller banjo bolt? If I keep the new master cylinder I hav3 to replace the line and the caliper which will be a pain. Thoughts?
Quite possibly you may be able to use THIS BRAKE LINE with an 8mm and 10mm end fitting
