Oil Change #8
I think I would have it down to a 15 minute oil change if it weren't for the drain time.
![]() This is the oil change that I plugged the air box and vented the crankcase directly to the atmosphere. Sample will be sent to Blackstone for analysis. ![]() The drain plug had only a small bit of particles on it, and the oil filter had no sign of sparkly bits. ![]() ![]() I've used seven of the paper oil filters, and now will change to the re-usable metal mesh filter: ![]() I also restored the OCS to its original configuration: ![]() Then cleaned the crud off the inside of counter sprocket cover: ![]() jb
