Location: 484 miles east from the geographical center of the United States
Tool Kit
I am a new RX3 owner. Is there a set of specific tools to have on hand at all times. Thanks.
"Tolerance is not the same thing as acceptance, and acceptance is not the same thing as an endorsement" Life Member VFW / Life Member NRA / WWG1-WGA |
The bike should have come with a mini kit under the pillion. They are pretty cheap but you could easily replace with higher quality tools. Beyond that it will depend on how "complete" you want your kit to be which relates to storage needs. I have a list of EVERY tool I have available depending on what kind of trip I may be on.
8" crescent wrench 8, 10, 12, 13mm box end wrenches 1/4" x 3/8" Dual Drive Extendable Ratchet 2" and 4" - 1/4" socket drive extensions 1 1/2" and 2 x 3" - 3/8" socket drive extensions 8, 10, 12, 13, 14, 17, 18 and 19mm sockets 5/8" spark plug socket 5 1/2" Metal file 1/4" x 36" Tape measure Hacksaw blade w/1/2 length covered with tape for handle Tire valve stem feeder tool Suspension adjustment spanner Spark plug gapper 4, 5, 6, 10mm allen wrenches Pocket knife Spoke wrench Slim offset philips driver Reversible standard and philips screwdriver 4 1/2"Wire snips 5" Needle nose pliers 6" Joint pliers 6" vice grips Para-cord OEM Spark plug .05/.08mm angled feeler gauge Bead Buster tire paste in Blistex tube Continuity tester WD-40 J-B quick weld Electrical wire Gasket maker JB water weld 12 tie wraps JB epoxy putty Blue Locktite Gorilla duct tape Silicon tape Electrical tape Mechanics/bailing wire Assortment of fuses Surgical gloves 520 chain master link Motion Pro BeadPRO aluminum tire levers/bead breaker set CT101 16" tire lever Bead Buddy II 2 Rim protectors Tube for front tire Tube for rear tire Slime bike powered tire pump Tire pressure gauge Tube patch kit (Patches and glue) 3' x 5' tarp Flashlight Rag Best Rest Products 5:1 Motorcycle Recovery System Chain lube Siphon Micro battery jump starter Bike specific spares Clutch lever Brake lever Shift pedal Brake pedal Clutch cable and housing Throttle cable and housing Front brake pads Rear brake pads Various nuts/bolts/screws Countershaft sprocket, washer, nut Fuel Filter
2017 BMW F800GS Adventure |
#3 | |
![]() Maybe you should carry a spare bike on that trailer, too. ![]() Or better yet, have Joe #2 accompany you at all times. ![]() jb
#4 | |
Funny thing is I'm like this with most of my activities and get teased often but it's funny how many times those folks end up coming to me asking for tools or parts to get them going again and generally needing me to do the work... ![]()
Joe2 mexgyver is the guy you want to have around if you break down. Way above my pay grade in all things geekish and practical.
Live Zong, and Prosper |
I know the feeling. It's how I became "2LZ". I was everyone's roadside wrench.
#7 | |
Certain types of people
#8 | |
I've seen tool tubes on pictures of 'real' adventure bikes but haven't seen any for sale on local sites. Any suggestions, or do I need to go to the plumbing store and then get creative? ![]() |
No offense, Joe....
![]() There is no one else I would rather have along on a trip than you....and all your gear/tools. I'm a bit of a tool hound. I have 7 rolling tool chests filled with all kind of stuff I never use. Not for on the road, but in the shop. Out of all the tools, I find that I can perform nearly all the maintenance on my RX3 with a 1/4" socket and bit set, plus a few box wrenches. ![]() Anyone else have some favorite motorcycle tools? jb
I knew about the mini kit. I wanted to refrain from saying "cheap chinese crap" since I just bought a chinese motorcycle.
The bikes are one thing BUT the tool kits are another. Thanks for the replies.
Regarding tools, it's not about the country of origin but the standard to which they're made. It sounds like you would be surprised by the origin of many high quality tools these days.
Horse holder at Madame Orr's House. |
Tools
No matter how many tools you carry it's always possible that something will go bad and you cannot fix it. Joe #2 has enough stuff to reduce that possibility down to near zero but still it exists. You will find that for most maintenance you will be using the same tools over and over. 8mm socket and phillips screwdriver along with a couple common allen wrenches will take the bike down to bare bones. After that you can decide exactly how prepared you need to be. Personally, I want to be able to fix a flat tire even though I have not had to actually do that for at least 10 years (and then on a tubeless tire). Oh, and most of my tools were made overseas.
Just for grins I'd recommend making a list of all the tools needed to do your 500 mile service. You'll find that it will be a short list. |
#13 |
That is a smart thing to prep for. Thanks.
#14 | |
#15 |
Joe # 2, Your very complete list of tools is still missing two that I would never go without on a long / RTW type trip.
Cell Phone & SPOT Many neglect to think of a cell phone as a tool but it can teach you how to repair, provide light, digitally store a copy of your manual & maps, send pictures of a failure to a mechanic for advice as many other things. |
