01-11-2022, 10:29 AM | #1 |
Will This LED Work On The 2021 TBR7
SaferCCTV H4 LED Headlight Bulbs, Motorcycle LED Headlight Bulb with High Low Beam Compatible with Electra Glide, Ultra Classic, Compatible with FLHTC FLHX, 6500K Cool White https://www.amazon.com/dp/B01EWH8YZE...ing=UTF8&psc=1
01-11-2022, 11:43 AM | #2 |
I installed these in my TT250 and my wife's TT250. The bulbs are so bright they light up speed limit signs on cloudless days. :-) I don't know if the connector and headlight housing is the same on a TBR7.
https://www.amazon.com/DZG-H4-9003-HB2-HS1/dp/B07BTW6RCG/ref=sr_1_5?crid=1600TWPQY86K9&keywords=dzg%2Bh4%2B motorcycle%2Bled%2Bheadlight%2Bbulb&qid=1641919194 &sprefix=dzg%2Bh4%2Caps%2C319&sr=8-5&th=1
___________________________________ 2021 CSC TT250 - Silver (Mine) "Buzz" 2021 CSC TT250 - White (Wife's) "Seymour" 2021 CSC TT250 - White (Daughter's) "Gemini" Last edited by Hunnicutt; 01-11-2022 at 01:08 PM. |
01-11-2022, 11:46 AM | #3 |
If the TBR7 takes a H4 bulb it will work. I installed this one on my Vulcan S Really bright as well. https://www.amazon.com/dp/B08BC4G48W...roduct_details
01-12-2022, 03:27 PM | #4 |
Thank you guy for your insight. I sure appreciate it.
05-17-2022, 05:42 PM | #5 |
Where you able get the H4 to work in the stock TBR7 housing?
05-18-2022, 04:37 PM | #6 |
Tbr7 takes an H6m : http://tbr7.com/upgrades/electrical/
The tbr7-d (you didn't clarify which you had) takes an H4 (like the hawk) |
