Old 05-14-2018, 10:08 AM   #16
kirkallen143   kirkallen143 is offline
Check the adjustment on the rear brake, it may be just slightly out of adjustment and dragging a tiny bit.
That was it, seems like the adjustment was just a tad on the short side. Once lengthened, stops on a dime. Thanks megadan for the heads up!
Kirk
Old 05-14-2018, 12:05 PM   #17
Kirk
Good stuff. It's not uncommon for these bikes to come shipped with the rear brake adjustment being slightly out of whack. More often then not, a bit on the tight side, but sometimes completely loose.
Old 05-15-2018, 12:58 PM   #18
nickdowny   nickdowny is offline
nickdowny's Avatar
If the link works, this is the one I ordered:
https://www.ebay.com/itm/11-280mm-Re...53.m2749.l2649
Let me know when you have it installed if theirs any issue's may have to order one next. The link works by the way.
Old 06-16-2018, 04:56 PM   #19
Hawk 229cc   Hawk 229cc is offline
Hawk 229cc's Avatar
hello
Well, I could at least give y'all a pic of the bike...
Kirk
nice bike where did you get the seat cover ,an the 2018 an 2017 are they the same my title says 2017 ,an crate sticker badge dec 2017 they look the same ,thank you
Old 06-16-2018, 09:26 PM   #20
dpl096   dpl096 is offline
dpl096's Avatar
Good looking bike...I like the blue.
― Thomas Jefferson
Old 07-25-2018, 12:21 PM   #21
Been awhile, work and life have kept me away from the computer...
Update on the shock: bought the 280mm one from ebay. First off, it did not come with a Schrader valve, only a cap of some sort (which I found out after install was loose, so no nitrogen...can you say pogo stick?). I tried it anyway, and I believe the shock is too short. The rear tire would bottom out on the air box. Maybe if the shock was filled with nitrogen it might not have, but I do not know? It sure was nice to flat foot the bike with that shock, though.
Emailed the seller and asked why no valve when it shows it in the pics on ebay? They say oops and we'll refund you $5. I say, just give me a Schrader valve from another shock and call it good. They say no got Schrader valve...
I blew them off, it has been well over 60 days since I bought the shock, and I ended up stripping the threads on the pre-load adjusting nut...Son-of-a-Bi*ch! I'll write that off as a life lesson.
Going to look at a 300mm shock for the next one, and make sure the seller is selling what is pictured on ebay. I believe it will be a good compromise.
Other than that, the bike starts when you want and idles like it should...on the stand. Oh, one more thing, watch those battery terminals! Mine had corrosion all over them.
Kirk
Old 07-25-2018, 07:33 PM   #22
Digger   Digger is offline
Good looking Hawk. The .018 size on the pilot jet, are you happy with that size?
Thanks
Old 07-27-2018, 08:28 AM   #23
Redbookaudio   Redbookaudio is offline
Kirk... very impressive Hawk setup! 12 miles? (probably actually only 8 or 9 miles if your odometer works like mine....) At any rate, it sounds like you have more fun working on the bike than actually riding it! Hit the trail already!! (I'm probably just jealous of how WELL you've done your research and put your bike together.... congrats!)
Hawk 250
Old 07-29-2018, 05:58 PM   #24
Thanks all for the compliments!
Digger, the 0.018" drilled jet seams to work good so far at sea level on the stock carb. and fuel mixture screw out 2 1/4 turns.
I think I am up to 80 kilometers now on the odometer...I'll get it broke in one of these days.
Now on to the shock...I ordered a 295mm one off ebay with the Schrader valve this time. They did not offer too many 300mm shocks, so settled for this. With me at 225lbs, the 280mm shock was too short and would bottom the rear tire into the air box on medium bumps (the lack of nitrogen in the shock could of have an effect, too).
I made sure and contacted the seller and asked them if it had one. This shock has a 1200lb spring with a dampening adjuster on the bottom, and how much nitrogen you want to charge it with (150psi is usually the max for most). Hopefully it will be here Friday and I will let y'all now the outcome.
Kirk
Old 07-29-2018, 06:13 PM   #25
Oh, almost forgot!
I changed out the fork oil and went with 7.5oz of 15W Belray in each leg and added 1" more of preload...LIKE DRIVING A CADALLAC! Not really, but it is 10 times better than what it was.
Hawk 229cc, the seat cover is from Walmart in the ATV section, ordered it online @ $20.
Kirk
Old 07-29-2018, 08:18 PM   #26
Thanks Kirk!
Old 07-30-2018, 05:22 PM   #27
Oh, almost forgot!
Kirk
Kirk we were thinking about changing the fork oil (although everything seems good with the original....but as newbies, we don't have anything to compare it to). I've seen videos about changing the fork oil, but what do you mean by "added 1" more of preload?" How do we do that? And is it important (my daughter, who rides it the bike the most, only weighs 120 lbs)? Thanks for any insight you can give to us!
Hawk 250
Old 07-31-2018, 09:34 AM   #28
RBA,
The preload spacer is just what it says, I added an extra 1" to the existing spacer that is inside each fork tube to "preload" the spring for my extra weight. Now it does not sag as much in the front. It sits on top of the spring when you take off the fork/tube nut, and is just basically a metal pipe (although SCH40 PVC can be used, also).
With your daughter, I do not believe she will need the extra preload for her weight, but some better fork oil, say 3W or 10W, and that makes a world of difference. Drain the original out, and you will have to play with how much you put in each fork leg, but start at @ 6-7oz and see how she likes it. The more oil you add, the more dampening you get, the thicker the oil, the slower the dampening will be. Once the forks are back on the bike, to add more I use a 10ml syringe, and if too much, I use some fish tank air hose on the end of the syringe to suck it out.
Kirk
Old 07-31-2018, 02:37 PM   #29
RBA,
Kirk
Thanks Kirk! We will change the fork oil as our next "project"....
Hawk 250
Old 07-31-2018, 03:43 PM   #30
ChrisWNY   ChrisWNY is offline
ChrisWNY's Avatar
Dan has a great video on youtube for changing the fork oil...the correct way to do it is to remove the front tire, the front brake caliper, loosen the cap at the top of the fork, then loosen the bolts on the triple clamps that lock the forks in place. Once you have the forks off the bike, you can take those end caps off (slowly because there is spring tension there), pull the springs and spacer out, then tip the fork upside-down and let the garbage oil drain out of the fork. I had mine changed out in under 45 minutes, 10 of those minutes was waiting for all the oil to drain out of the forks. Of course, this task is much more difficult if you don't have a scissor jack or something to keep your front tire elevated (a milk crate will do if you have someone help you lift it up there). You can find scissor jacks on Amazon for around $50...they're invaluable for DIY motorcycle work.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For reference, I used 20W Maxima fork oil...about 200mL in each fork which was probably overkill in my case (I'm barely 175 lbs, 5'10"). I prefer stiffer forks and wanted to prevent them from bottoming out, especially if someone heavier rides on my Hawk. A quart of fork oil runs anywhere between $5-$10 and can be found at ATV/dirt bike shops and sometimes department stores.
Here's the video - skip to about halfway through where he explains how to properly change the fork oil...
2018 RPS Hawk 250cc
Mods so far:
1. Mikuni VM26 Carburetor w/#115 main jet
2. 17T/45T JT sprockets
3. JT 428 X-ring chain
4. Air box mod
5. Hawk Digital Cluster
6. Aftermarket IMS shift lever
7. Performance Aftermarket Exhaust
8. 295mm Nitrogen Gas Monoshock, 20W oil front forks
