Old 05-18-2023, 11:44 AM   #1
mcfischer   mcfischer is offline
Brozz 250 Rear Wheel
I have a 2018 Brozz 250 with the disc brakes and I can't seem to find a new rear wheel cause mine is bent. Does anyone know if there's one I can just swap on.
Old 05-18-2023, 11:53 AM   #2
I don't know if you're talking about a Recon, or the Sport, but I would say there's a pretty good chance these would work. The say for 2022, and they are the larger size. You could also call Peace Sports, and they may be able to get you one exactly like you need.https://shop.brozz250.com/eshopprod_...heel_Combo.htm
Old 05-18-2023, 12:19 PM   #3
I had called peace sports and they said they'll be out of stock of the 17 till sometime in fall. Do you know if I could just keep the 19 in the front and put the 18" they sell on the rear.
Old 05-18-2023, 05:48 PM   #4
I would say it would work. I figure the only reason it says 2022 only, is because it's the only year that came stock with the 18 rear .They could probably tell you for sure.
Old 05-19-2023, 02:11 AM   #5
Do you know what the width of the rim for the 18 is
