11-22-2023, 03:29 PM | #1 |
2014 Bashan Storm 200 Running issues.
So far I have:
Put Seafoam in the tank Replaced the old battery Changed the air filter system to a pod just because its easier to get a filter for it Tuned my carbs What happens: I turn it on, it idles ok in neutral. I switch gears into 1st and as soon as I release the clutch it stalls. Mind you my kickstand is up. I don't know if these have kickstand switches but my bike does not appear to. Videos below for further help. When it stalls I do notice my carb has some small amounts of smoke leak from under the filter. https://imgur.com/dvnyjQo https://imgur.com/Jr4NGjD Please help this is my only way to get around. |
11-22-2023, 03:38 PM | #2 |
Your idle sound kind of low. It should be idling around 1500 rpms.
11-22-2023, 03:40 PM | #3 |
Do I just adjust with the idle screw? Clockwise or counter? Sorry I am kinda new to bikes still.
11-22-2023, 04:01 PM | #4 |
Clockwise will increase the idle speed.
11-22-2023, 04:09 PM | #5 |
It just sounds like it needs more rpm to gain enough power to pull you forward. After you get it in gear, rev it up before you begin to let the clutch out!
By the way, that idle screw just props up the slide inside the carburetor higher as you tighten it (clockwise). It is on the right side of the tower near the bottom of the slide.
11-22-2023, 05:54 PM | #7 |
Bumpy as in stiff suspension?
11-22-2023, 07:30 PM | #8 |
No bumpy as in it feels like im ever so slightly dragging brake.
