10-16-2018, 03:54 PM | #1 |
Brrrr! Carb woes
Now that it’s into the 30’s here the bike needs a long warm up before you can use the throttle without killing it. I’m told I probably need to adjust the mix screw as they run better a little rich in winter. I know the idle adjustment screw and the every just slightly leaky bowl screw. What I can’t find on the carb or online is the mixing screw real or faux. I’m guessing it needs to be slotted in the head to be turned but can’t find it. Thanks for the help as always!
