Old 02-13-2025, 10:05 AM   #1
allybarrie   allybarrie is offline
Help with Chinese ATV stator wires
Looking for a bit of tech knowledge. New to this stuff and I have a 110ccchinese quad. I've bought a new wiring harness and that includes the stator. Bit of web digging and I've got the accessories plugged in, however the stator has two yellow wires (plus a green ground, red 12V I assume, and blue to the magnetic pick-up in the stator), where the harness connections for the stator has one white and one yellow (plus a red, blue and green). No wiring diagrams (naturally) that are specific to the harness kit I bought from amazon.
At this stage, the white I thought might be a charging 12V line, and the yellow to then CDI.
Anyone able to offer any detail on tracing the yellows from the stator (two different tappings maybe) and the yellow and white on the harness to let me finish the connections?
Thanks
Ally
Old 02-13-2025, 12:14 PM   #2
Mudflap   Mudflap is offline
Maybe this will help.
Old 02-13-2025, 12:17 PM   #3
Where it says electrical accessories is where regulated 12v (14.5V) AC lights etc., are wired in.
Old 02-14-2025, 09:24 PM   #4
shad88   shad88 is offline
You can plug either yellow into the white and the other into the yellow. I've never had them make a difference.
Old 02-15-2025, 09:11 PM   #5
Thank you guys.
I had buzzed them both and seemed that both the white and yellow both have a lath to the 12 battery terminal so I did wonder if would work either way. I’ll give that a try. Much appreciated.
