11-11-2024, 03:49 PM | #1 |
Big bore kit for 223cc/zs165mm
hey guys.
Not sure if this is a bad solution, but I was really hoping to bore out my 223cc/zs165mm on my Vitacci Titan EFI. The only bore kit that fits the 15mm wrist pin available will go from a 65mm piston to a 67mm piston. I dont find that gain worth the effort. But I was wondering, could I use 15mmIDx16mm or 17mm to fit the larger wrist pin requirements of other cg250 big bore kit. Just raise the wrist pin OD to fit the 17mm 72mm-75mm bore kits. Let me know what you think. I know its going to have ramifications to compression ratio and EFI flash but would this wrist pin sleeve solution even be viable. thanks. existing max big bore kit https://gstreetperformance.com/cdn/s...8155&width=990 bore kit that would require sleeve to raise from 15mm wrist pin to 16mm wrist pin. https://www.aliexpress.us/item/32568...yAdapt=glo2usa |
11-11-2024, 04:56 PM | #2 |
You intend to use the stock 15mm wrist pin from your engine and insert sleeves to use a piston that takes a bigger diameter wrist pin? Not sure I'd want anything to do with that, but that's just my 2ยข...
01-15-2025, 06:21 PM | #3 |
check alixpress ive found a 70mm bigbore kit for the engine and it was a 15mm wrist pin size
01-15-2025, 07:12 PM | #4 |
70mm bigbore cylinder kits wont fit any GC engine below a 167FMM.
it wont fit, the head studs are positioned different and the cylinder skirt OD 73mm wont fit into the case. Gudgeon/wrist pin sizes are the lest of problems... If you want more power save up and get a pr172-fmm PR175-fmn-5 300cc* (5 or 6 speed with or without a balance shaft) or a 4 valve CB300RL some fabrication required. Or just got to wall mart and get a CG250 for less than $500USD. I've done the CG250 70mm bigbore kit, I would only consider doing it if you old cylinder and piston is worn out as the power increase is negligible. |
