Old 03-09-2019, 05:46 PM   #1
Douglass   Douglass is offline
Douglass's Avatar
2017 Apollo RX250 Mods and upgrades
I wanted to do an update with pictures of the Apollo. Last weekend I installed Bridgestone BattleCross X30 tires, with new heavy duty tubes. I also replaced the rubber strap that goes around the inside of the wheel to protect the tube from hiting the spoke fasteners. Since the bike was apart I measured the suspension linkage to raise the bike. I also made an attempt to replace the rear shock with a 1990 KX125 rear shock, and it was a fail without modifing the bike. I ended sticking with the stock shock, and backing off the spring collar to soften up the rear a little bit. Since the swing arm was raised so much, I did have to drill a new hole for the lower chain roller. New seat height is about 37" from the ground to the lowest part of the seat.
Here is a list of everything I have currently done to the bike:
- CRF High Bend Tusk handle bars
- Protaper Crossbar bad, with Protaper pillow gripps
- Yellow spoke covers
- 2017 Honda CRF230 front fender - UFO brand
- Bridgestone Battlecross X30 tires 80/100-21, & 100/100-18
- Heavy duty Tubes front and rear
- Mikuni VM26 Carb w/27.5 pilot, & 120 Main jet needle clip in the middle
- NGK Iridium spark plug
- Shortend suspension linkage
- Rear sprocket 52T - Custom made - PBI brand
- 530 Oring Chain unibear brand
Old 03-09-2019, 07:04 PM   #2
Bikes is looking real nice.
Old 03-09-2019, 09:18 PM   #3
Its_not_a_honda   Its_not_a_honda is offline
Let us know how that linkage works with the stock shock. I did a mod on mine that works really good so far. Have to do a little more testing before posting all the technical stuff. Did it without modifying the frame and such. Your bike looks great! What do you clean it with? Mine looks dirty even after I wash it.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 03-09-2019, 10:49 PM   #4
Douglass's Avatar
Thank you Jerry
I am anxiously waiting to hear what you did. When I was bouncing on the bike in the garage, it seemed to compress good. Hopefully the weather will hold, and I can take it out next weekend.
When I get done riding the bike I spray it down with a pressure washer. I have a foam cannon that I use, and foam the bike up real good, let it sit on the bike, then scrub as much area as I can. After that, then I pressure wash off the soap, use a blower to blow out all the water from the bike, and electrical connectors, then use my chemical guys detail products to finish it up.
Old 03-30-2019, 11:55 PM   #5
Bruces   Bruces is offline
From what I can see ,you have the clip on your master link backwards ,that is assuming your pictures of it are oriented correctly .
Old 03-31-2019, 12:44 AM   #6
Douglass's Avatar
In the two close up pictures, the chain is under the swing arm. The closed end of the master link would be going towards the rear sprocket when the bike is going forward.
Old 03-31-2019, 09:09 AM   #7
Sounds perfect Douglass .
Old 04-28-2019, 08:00 AM   #8
Kivi   Kivi is offline
Nice bike!!
Do you have a pic of your new vm26 carb?
That chain roller is not under spring load, right?
Old 07-01-2019, 09:45 PM   #9
leofrozenyogurt   leofrozenyogurt is offline
Looks super nice! Do you know if an exhaust for the 230f will fit on it?
Old 07-02-2019, 10:30 AM   #10
Douglass's Avatar
Nice bike!!
I don't have any close up pics of the carb, and the roller is not under load
Quite honestly I have not looked into it. The bike runs/sounds good, and have not felt the need to mess with it. I am considering trying the Nibbi Carb.
Old 07-02-2019, 09:05 PM   #11
Do you think this one would fit on it? Just based on your experience with the bike
https://www.amazon.com/gp/product/B0...9O1GWX3X&psc=1
Old 05-22-2024, 06:53 PM   #12
Chinaridermi   Chinaridermi is offline
Ay, you can use a crf250 shock on these bikes if you notch out the frame
Old 05-22-2024, 06:54 PM   #13
You just have to use a ratchet strap to compress it a little bit while installing and drill a hole further down for the lower bolt
Old 05-22-2024, 08:10 PM   #14
It is in the correct orientation. That is the lower side of the chain-going back to the rear sprocket)... The open side of the link is trailing, which is correct.
