Old 11-16-2024, 08:28 AM   #1
NYCDiesel   NYCDiesel is offline
Templar M keeps draining battery
Hey guys, my templar's battery died last week so I ordered another. I installed the new battery, bike started, ran great but than as soon as I killed the engine the battery was completely dead again, really annoying. I'm guessing its the rectifier, but when I attempt to kickstart it the dash lights up for a second which makes me think the rectifier is OK. Would really appreciate any help, thanks
Old 11-16-2024, 09:30 AM   #2
Got a voltmeter?
I would start with testing the charging system. Here is a post on this
https://www.chinariders.net/showthread.php?t=34080
Old 11-16-2024, 12:45 PM   #3
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
You should check what your charging voltage is at the battery.
Old 11-16-2024, 01:16 PM   #4
J4Fun   J4Fun is offline
How long did you run the bike on the new battery? Is the battery a wet cell and is it properly filled with electrolyte and charged before starting? Once it is started the voltage check at the battery will no doubt tell you you have a charging problem or not, look for around 13.5+ v while running and check with some throttle too to make sure. My thoughts…
Old 11-17-2024, 02:41 PM   #5
Definitely worth throwing a charger on any new battery and making sure it's fully charged before putting cycles on it
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old Yesterday, 05:46 PM   #6
Yeah I made sure the new battery was properly charged, I do have a voltmeter and have seen that thread just hard to check it wo the bike running. The OEM battery was so depleted that it wouldn't take a charge, if i remember correctly it was somewhere around 3-4 volts. I'll try to recharge the replacement and get back to you, thanks for all the help.
Old Yesterday, 08:53 PM   #7
Your first post above stated that the bike runs. Yes, those tests need to be run on a bike that starts so you can check voltage at the battery running ~1800 rpm. Compare that to resting (not running), first disconnected and then connected to test for a short.
