Old 09-10-2024, 08:12 PM   #1
Boozer350   Boozer350 is offline
TBR7 Aux power loss
New to posting here, but have got tons of info from you guys that helped me a long way. One thing that has me stumped though I have a 23 TBR7. I removed the aux power that goes to the USB charger and used it to power an android auto device. While riding I noticed if I lug the bike on take off I lose power to that device, not anything else as the factory cluster stays powered on. I pulled out the wire harness behind the headlight a soldered the connections that go to that device as I noticed the connectors are junk and when you wiggle them it cut out. Just a little lost because all connects are solid now and if you shut the bike off with the kill switch and not the key it stays powered on. It's a brand new upgraded battery so I figure it should hold power up even if I do lug/stall the bike. Any incite?
Old Yesterday, 09:58 PM   #2
CheapThrills   CheapThrills is offline
Read you post, I immediately thought 'loose connection', but you seemed to cover that.
Now it's weird that voltage would drop with "lug the bike'.
I would use a voltage meter, tape it in place and try running the bike at different rpms and see if there is something with the charging system.
Good luck.
- My 3 Bikes:
1. TaoTao TBR7 (My TBR7 Upgrades)
2. Boom Vader (FYI: My Boom Vader Upgrades)
3. 1978 Suzuki SG750
Testing a YouTube Channel
