Old 11-13-2024, 09:03 PM   #1
Pitbike Tuner   Pitbike Tuner is offline
110cc - Wierd TDC Issue
Trying to get my engine to top dead center and have the 2 covers off. Issue is when turning counterclockwise and looking thru the top hole for the "t", whenever the engine gets to it it turns quickly past it and I cant get it to hold there. I had the spark plug out as its threads are stripped and I'm going to change the head to fix that issue, but even putting the sparkplug in it does the same.
2010 ZheJiang YX110cc ATV
2008 ZMC125r Pit Bike
2007 Viper Z32 (X15) Super Pocket Bike
Old 11-13-2024, 09:30 PM   #2
At TDC both valves should be closed and there should be no spring pressure on the cam. If you're sure it's at TDC and not in between then could it have jumped timing or valve adjustment too tight? Did the engine run ok before? Find a way to lock it down at TDC and check the valve adjustment.
Old 11-14-2024, 11:28 AM   #3
TominMO   TominMO is offline
Use a wrench or breaker bar to turn it, not something with a ratchet. That gives you a lot more control.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 11-14-2024, 09:01 PM   #4
Not sure how it ran before, got it from someone who said it wasn't running and found out the spark plug threads were stripped. It turned over fine when trying to start, and came with a new complete head so think the guy new of the issue. The engine turns without much resistance at all, and then when it gets just to TDC it spins quickly about a half turn.
So to check the valve adjustment just pull the top and bottom caps after getting it at TDC correct?
Old 11-15-2024, 06:10 PM   #5
cheesy   cheesy is offline
cheesy's Avatar
Pull the caps first. Set crank at TDC. Both valves should be closed as Crossbar said. If one valve is open, rotate the crank one revolution and line up with timing marks again for TDC. Both valves should then be closed. If still not, the engine has jumped time.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 11-16-2024, 09:40 PM   #6
krat   krat is offline
Questions;
Are you installing the new head? If so you set TDC on the flywheel and install the new head and adjust the valves to match. That should also take care of any timing problem that might have existed. You will line up the cam and lifters to the new head with the timing chain in the proper position.
It also makes the spark plug issue a moot point.
Otherwise, why would you try to adjust the valves on a head that was trashed?
Old Yesterday, 08:51 PM   #7
Originally Posted by krat View Post
Questions;
Yes, installing the new head.
I'm just wondering if the engine has an internal issue as it seems way to easy to spin, no resistance pretty much, and quickly went past TDC when turning it with the wrench and it hit close to that point.
