Orion rxb150xl
I need help finding a manual or specs and parts for a Orion rxb150xl does anyone know of anything.
#3 | |
#4 | |
-NOS 2020 KTM 250SX (2-stroke motocross) Last edited by Thumper; 07-22-2024 at 05:19 PM. |
Thing is id like to have to put as little money in it as possible and keep the original engine and I talked to Orion power sports and they said the the 190xl has a frame that’s two inch’s longer so I wouldn’t be able to do swap unless I fabricated something up
#6 | |
Cracks? Starter? Got pics?
So the starter ended up completely cracking off I dried to jb weld it back to gather and it cracked off again so now it’s quick start only but when I ride it there is raffling some of it comes from the kickstart just vibrating on swivel it’s connected too but there is more raffling sounds like it’s at the front of the bike or engine I think it’s my valves or rockers and lifters hitting and I think they need adjusted but can’t find the correct lashing gap for it would anyone know anything? Or have a manual
Is the 2021 orion rxb 150xl a wet clutch or dry and what oil does it take
It is definitely a wet clutch, and it will take any JASO MA or MA2 rated oil, the weight of which will depend on your locations temperature/climate.
That said, my buddy who has one runs 15W40 (yes, Rotella of course) in his since the temperature range seems to encompass everything we experience and then some. |
#10 | |
Can't install a new starter?
If necessary, tap new thread, and use a size bigger bolts if necessary. |
orion rxb150xl |
