06-30-2024, 11:57 AM | #1 |
Should I re gap spark plug for stock motor?
As most know, I had a cam follower fail on my fairly hot CG Hawk motor, and it took the timing gears out in the process. I quickly slapped a stock motor on it , from a parts bike I bought, which was showing around 700 miles, but probably abusive miles. It runs good for internally stock, and I am running a VM26 with 110/25 jetting . I had installed one of the Nibbi Yellow coils, not long ago, and gapped my plug to .9 mm. I used this same plug for the current stock motor. Should I reduce the gap to about.7mm, or leave it at .9mm ? Thanks
06-30-2024, 04:23 PM | #3 |
It isn't going to make a difference either way.
06-30-2024, 07:09 PM | #4 |
Anyone that would worry about +- .2mm spark plug gap has never watched ItchyBoots being passed by a Chinese motorbike, axle deep in the mud of a west African dirt track, while being chased by elephants and pigmies.
06-30-2024, 10:17 PM | #5 |
so true ,should not ride a at all
06-30-2024, 11:33 PM | #6 |
You can leave the gap alone. I ran the Iridium plug with it's .9mm (.036") gap on my first Hawk for 4400 miles, and that bike only had an exhaust and the same carb. The fine point iridium plug creates a more focused arc point, so they are much more likely to jump a wider gap and with a consistently hotter spark.
Now, if you can hear it missing a hit or two, especially at idle, then you can definitely shrink the gap a bit. Running a .028" gap (.7mm) is perfectly acceptable. That is still wider than the factory plug gap (.6mm). You can also compromise and split the difference between the stock gap and the iridium .9mm gap and run a .030" gap, which is between a .7mm(.028") and .8mm(.032") gap.
Yesterday, 09:56 AM | #7 | |
Yesterday, 08:51 PM | #8 |
Smaller gap only if your compression ratio is 9.5:1 to 10:1 (water cooled).
For air cooled, especially if you are running close to stoic ratios, the stock gap will do. |
