Yesterday, 10:47 PM | #1 |
Make sure you check the valves on these.
I had to tighten my valves twice within the first 1k miles (they come right from the factory, but loosen during the break-in). With proper adjusted valves, the xpect should be able to maintain idle down to 1.1k rpm, however, don't set it that low, even if it does idle fine. Many threads about ruined camshafts due to too low idle (and not enough oil flow) |
