Old 02-10-2013, 12:37 AM   #1
damo19854   damo19854 is offline
zongshen 250 carburetor
hi all i have a zongshen 250 air cooled model i got a new carburettor for it and i cant seem to understand why it is leeking fuel from where the air box conects as soon as i turn the fuel tap on the bike still starts and idols i just cant understand how to fix this can anyone give me any sugestions PLEASE!!
Old 02-10-2013, 08:53 AM   #2
katoranger's Avatar
Sounds like the float may be stuck in the carburetor.
Old 02-10-2013, 11:08 AM   #3
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
tap carb with a wrench in multiple places. it may un-stick
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 02-10-2013, 05:36 PM   #4
I pulled the float cover off it doesn't seem to be Jamd would anyone know wich way the fuel lines go on or would anyone have a setup instructions for it it's a mykuni 30mm carburettor
Old 02-10-2013, 07:38 PM   #5
As always, Kato and WA gave you excellent advice. The float bowl valve is surely stuck. I'm moving your thread to the Pure Dirt Forum, where you will get more replies concerning your dirt bike.
Old 02-11-2013, 01:32 AM   #6
openthrottle55   openthrottle55 is offline
Check and see if the brass peice your fuel line connects too is cracked or loose, mine was. Also if the fuel knew doesn't have a clip on it holding it tight it will leak down and you may think its float but its fuel line.
Old 02-11-2013, 02:41 AM   #7
Indeed, those a very good points. Thanks for the good input.
Old 08-17-2024, 09:54 PM   #8
Mogssxcii69   Mogssxcii69 is offline
My zongshen 250 running shi@
My zongshen 250 won't run unless the choke is on or if its off I have to keep revving the engine up and down or it stalls what's the problem and how do I fix it I don't have any knolage on bikes I just watch youtubethen try my self so if u have a dumys gidetofixing this problem I would love to know
Old 08-18-2024, 12:38 PM   #9
buzz   buzz is offline
Carburetor needs a good cleaning,something is plugged up.Or just get a new carburetor,there cheap. Best of luck.
