Today, 01:13 PM | #1 |
Lean angle
Hi all,
i will start off by saying i have a 2022 HAWK DLX EFI. i want to know what the "proper" or excepted lean angle is for the bike on its kickstand. here is what mine looks like. is this normal? i don't recall it being this bad to begin with, but maybe it was. i have checked and nothing is cracked, twisted, mangles in anyway where the kickstand mounts. all looks like it should i assume, no paint missing or cracked either, so i assume it hasn't moved or bent in anyway. let me know what you guys think. hand if this is :"normal lean" how can i improve this so it isn't leaning so far? is that just getting a new kickstand that is longer? |
Today, 02:58 PM | #2 |
That to me is excessive lean by what I see in the picture. My 21’ Hawk DLX kick stand measures from the center of the mounting bolt following the center of the stand to the ground approximately 13 1/2” is yours the same? Because there has been lots asking the same question I believe it probably is the kickstand weld-mount that’s the problem. My bike only leans half as much as yours. Others may chime in on what they did to correct the problem. I think some carry a small 2x4 block to raise it up more. My thoughts…
Today, 06:23 PM | #4 |
My Hawk leaned that far over too. After lowering the back of my bike a bit over 2 inches it now leans at an appropriate angle. The kick stands are about an inch too short imho.
https://ibb.co/S53p5Sj
