Old 11-30-2022, 02:28 PM   #1
Hap   Hap is offline
Templar X 250 Oil Cooler.
I’m thinking about a possible oil cooler install on my new Templar X. Possibly a dual setup. The frame on the Templar X/M is designed to accommodate a radiator. I am hoping to mount one oil cooler on each side where the plastic air vent things are located. They are very easy to remove. Leaving a metal frame that is needed to attach the front of the gas tank shroud. Anyone have any thoughts about this?
Old 11-30-2022, 02:38 PM   #2
I have dual cooler installed on my Hawk. It should be much easier on the Templar i would think. Looks like the templar has more room to work with.
Old 11-30-2022, 02:56 PM   #3
Hap   Hap is offline
Yes sir! The setup you have on your Hawk is what inspired me to do one on my Templar. As far as connecting the two. It’s just a hose from the outlet on the first one to the inlet on the second. Correct? May I ask were you able to purchase a kit with everything already supplied? Or did you fabricate yourself?
Old 11-30-2022, 03:40 PM   #4
I originally had a single cooler. Megadan had donated the other cooler with hoses to me. But yes you are just connecting the two coolers in a series.
Old 11-30-2022, 05:39 PM   #5
Yeah you can simply do them in series like Jerry. If you have the desire and ability you could put them in parallel with some Y fittings.
If you do want to go with dual coolers I would say try and use the stacked plate cooler style over the tube and fin. Tube and fin style coolers are much more efficient and you may find your bike will take a long time to get the oil up to temp with two of them (especially on cooler days). The stacked plate coolers don't cool as efficiently but are also much more durable.
This is an example of the stacked plate style. If you look at the second picture you can see how it is constructed https://www.walmart.com/ip/Motorcycl...erId=101229043
Old 11-30-2022, 06:00 PM   #6
This is what i used on my KPX. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 10-03-2024, 02:35 AM   #7
ea77i   ea77i is offline
my question is wouldn't this reduce the flow of the oil? i have one on my Hawk with the Templar x 250 cc engine in it and I feel more heat around my legs with the oil cooler installed I'm aware it's doing its job but I feel like it's reducing the flow of oil
Old 10-03-2024, 02:58 PM   #8
Or the heat your feeling is radiating off the cooler that's closer to your leg than the crank case is?
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
