This is a collaborative effort that will be updated as new information becomes available. Please contribute what you can and leave discussion in other threads. We want to keep this thread limited to Templar 250 spec's, facts, useful info and links. Thanks to everyone in advance for your contributions!
Below are the guidelines for contribution:
-No live links to external vendor websites like Amazon (they die, sometimes quickly)
Instead, include the full description that can be googled, and you can mention the vendor(s) that have it to make it easy to find.
-No personal posts about your bike. Start your own thread to post that, or questions for forum members to help you out
-Links to ChinaRiders threads or individual posts are definitely useful, because there is lots of useful information hidden all over this website.
-Do not post untested parts or methods, only things that are proven to work. A link to your successful install or procedure on your own thread is perfect.
-Photos can be very useful if you have them.
Thanks!
Brakes:
Front & rear pads: FA86
Carb: Youall PE28, 120 main jet, 40 pilot jet, 1.5 turns out on idle mixture screw
*Suggested jetting start point for 0-2000' ASL: 125 main, 42 pilot, +1mm needle, 1.5 turns out on idle air mixture screw (YMMV)
How to:
https://www.chinariders.net/showpost...3&postcount=25
https://www.chinariders.net/showpost...79&postcount=5
Exhaust: https://www.chinariders.net/showpost...3&postcount=28
Valves: Clearance .05mm +/- 0.02mm (.001-.003") *Cold
How to:
https://www.chinariders.net/showpost...4&postcount=23
https://www.chinariders.net/showpost...&postcount=496
Spark plug: Torch D8TC (oem), NGK D8EA (copper), NGK DPR8EIX-9 (iridium)
GAP: 0.6-0.8mm (.024-.031")
Ignition: https://www.chinariders.net/showpost...35&postcount=9
Headlight bulb: Base Templar: H6 BA20D, X/M: H4/9003/HB2
Replacement headlamp
Front sprocket: 13 tooth
Rear sprocket: X: 49 teeth Base/M: 47 teeth
X/M*
2022 Base/M*
* Templar M is known to ship with hubs drilled for either JTR210 or JTR897. Measure before ordering.
* Titan 2023+ now uses JTR210
* Oilcan has a 2023 Templar that uses JTR210 so 2023 Templar owners should measure before ordering.
Chain:
Templar: 520x112L
X/M: 520x112L
Body panels: X/M = 2007-2009 Suzuki RMZ 250 (fitment verified), Base = 2013-2016 KTM 125-450 (unverified, try at your own risk)
Front forks:
https://www.chinariders.net/showthread.php?t=32140
Rear shocks:
https://www.chinariders.net/showpost...1&postcount=22
How to lower your Templar
Texas Pete's Torque Spec's
Texas Pete's wheel and tire specs and fitment
Special thanks to Thumper for pioneering the way for future Templar owners, JerryHawk250 for moderating this great forum and all the members who contributed to this resource.
