Old 12-22-2022, 09:43 PM   #34
Fast_Freddy   Fast_Freddy is offline
Fast_Freddy's Avatar
If you want the optimal range: 1 1/4 and 2 1/4 turns out if your motor is behaving as it should be between these ranges (Step 2. in full carburetor tuning post) then you have the correct pilot jet size.
If you want a process to do a full carburetor tuning:
https://chinariders.net/showthread.php?t=31995
Thanks Pete! I'm starting off with modest one step richer pilot and main jets and 2 washers on the needle. We shall see.
22 Templar 250
