Originally Posted by Falkon45
Mine came with a bottle of coolant. It looked to be similar to engine ice, but in a random bottle. I use engine ice in all my bikes. It works really well, and you don't have to mix it. But, it is not compatible with and not to be mixed with any glycol based coolant. So, if you do use it, make sure you flush your system well first.
It doesn't take much. I thought it would take more than it did, seeing as I had to fill two radiator, plus the engine, but it didn't even empty the whole quart bottle.
You've got me scared now. My bike came with oil and gas in it. I made the assumption that coolant was in it as well and that the silver bottle was replacement oil that I just wasn't going to use because it was some dumb unlabeled stuff. Press F in the chat.. I've put 500 miles on it without it throwing a code, just put the silver bottle coolant in it now. Anything I should keep an eye out for since I probably damaged it in some way?
