Originally Posted by Biker_Andy
In terms of Amp rating for A1 & A2
Amps = Watts / Volts
therefore around 10 Amps each
Remember this is/was park n light switch so if you’re on A2 it’s pulling all from 1 wire to 2 wires, is not say 20amps on input and 10A on each out.
I’d be suggestion 10A total so 5A each msyve
Best use these for trigger on a relay to be fair
This system is altered in the USA and they change the wiring a little due to regulation of light must always be on.
