Mine will only stall a short time after starting if its getting down to freezing temperatures. Never does it when the engine has warmed up.
For me, it won't stall if you crack the throttle open a little bit before you hit the starter. Once running you can then release the throttle and it will remain idleing.
If you have difficulties re-starting, try opening up the the throttle fully before pressing the starter but be ready to shut the throttle down quickly once started as sometimes it will rev like a beast.
By doing this it enters into an Anti-flood condition at cranking speeds and shuts down the fuel injector pulse.
If all else fails, turn off the ignition, wait 15 secs, turn back on again and try again.
